Am in the process of removing a cheap crappy alarm fitted to my R34 4 door and replacing it with a better one. Found the trigger points for the passenger doors ok and figured out how to trigger drivers door. On removing drivers door trim to check wiring i found this box wired into the mirror switch. From some research I believe it to be the module for the auto swing away mirrors. It had been disconnected but I would love to see if I could reinstate it. One side goes to the mirror switch and is plug and play. The other three wires however have me guessing. I split the box and they are marked on the circuit board as follows.
B+ (Straight 12v or Acc/On ?)
Earth (Obvious)
Sig (Trigger wire possibly?)
Its the signal wire that has me stumped. Am presuming that it was connected to the dealer/factory remote central locking to which I didnt get a remote for and was activated when you locked the doors either by key or remote. Anyone got any ideas?
https://www.sau.com.au/forums/topic/427730-auto-swing-mirrors/
Sorted. Thanks Chris. you were right in that they take their power and signal from the keyless entry module. Power from pin three and signal from pin six. At first there was nothing. Had the switch on the door in the neutral position thinking that the module overrode the switch function. Wrong it has to be switched to the out position to work. A bit of buggerising around but is now working. Hit the lock key on my remote and the mirrors swing in. Turn the ignition on and they swing out. Cool little feature with no real use here except for the novelty factor I guess.
Hand for tight street parking. Or in my case Redcliffe street parking where the idiots get within 2" of your car and destroy mirror housings.
yes. i once got back to my car with the driver side mirror facing outwards.....i was very pissed off but the person/car that did it was no longer there.
Where can I get one of these little modules? I would love for my mirrors to swing in and out automatically.
Tommy_J <<<--------- This fella had some, I bought one from him but haven't installed it yet...
Mine is a factory nissan accessory item. Read on another post that someone used a jaycar module for auto window rollup to do the same thing.
Hey man I've just been searching the forum to find it but I can't find it anywhere, would you be able to direct me in the right direction please, thanks.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
