But then you can't get the injectors out on a neo. leaking between runners wouldn't matter. Another pointless option would be to get a machine shop to machine the base of the plenum for individual rubber orings. Then you will save money on gskets :)
I would just get another manifold
Yeah I don't really want this to get overly complicated, its a massive PITA cause was hoping to get it tuned
Cars been jerky and had a constant miss for the last year, pretty sure this was the cause so just want to fix it once and for all so I can ram some boost down its throat. hmm, might get new lower half runners and new OEM gasket and torque to exact specs and see what happens, theres no room to get a torque wrench in there so will have to put together out of the car this time then bolt it to the head,
if it leaks again ill just torch the car .. lol
got myself another manifold and have taken the old one off,
Anyone have tips here to ensure a tight seal on both manifold to head and plenum to lower runners?
this new manifold has been powder coated so should I sand paper that off at the flanges to create sanded surface or does it not matter? want to do this right first time so to speak...
use any gasket goo or leave clean and just assemble?
picked up the OEM gaskets from the dealer today, asked the guys behind the counter and one guy said the manifold Is likely warped and to get it faced, the other guy said the OEM gasket wasn't designed for high boost and wouldn't handle more than 10psi and I should get a steel gasket made up..
Got me considering welding it or having some kind of steel spacer made up..
opinions??
took the manifold to the engineering shop and all the flanges are warped upto 0.5mm, and to have them faced is $480, that's for 3 facings
Is it normal to have this happen on an intake manifold, or maybe its meant to be like that and the rubber OEM gasket takes up the gaps?
maybe it was overheated, the old exhaust manifold was warped but that's bit different, wondering now wether the cylinder head along the flange would be warped too, will get these bits faced anyway..
Yeah that's what I thought, taking it too another mob tomorrow which have quoted 80-120 per flange, bought a second whole manifold few days ago and it too is warped, im going to stick with stock manifold because from reading forums it sounds like the most ideal design etc for a street car...
can anyone confirm, should I be using any gasket goo for the fitment or bone dry and clean?????? sounds like a silly question but this will be about my 4th time with this and its becoming a joke.. :)
You only need a very light coating on the gasket, Hylomar still relies on a flat surface. If the flange is that warped that the gasket squishes out one side you will continue to have issues I think.
You could possibly try gluing a few sheets of sand paper to a thick pane of glass and using that to flatten it out, may take a while but I have seen it work on heads before. (bush mechanic style)
  • Like 1
opinions??
10psi? really? I had 1.3bar going into the stock gasket, zero leaks..
if you're having this much issue, I believe you may have a warpped intake manifold as others have mentioned.
Hope you get it sorted soon aye? I know the feeling when shit doesn't go your way you just wanna burn the damn car :(
I tried scraping most of it off and still squeezed out, my old man suggested I just use the Hylomar and remove the gasket all together so im going to try that..
yeah it does have a very slight warp which the engineering shop said was hardly anything and that it must be how im bolting it up, will see how I go today bolting it up without the gasket altogether,
fingers crossed :/
But then you can't get the injectors out on a neo. leaking between runners wouldn't matter. Another pointless option would be to get a machine shop to machine the base of the plenum for individual rubber orings. Then you will save money on gskets :) I would just get another manifold
leaking between the runners would matter as the runner from one would be robbing the intake charge from the other, hence why the gasket seperates one runner from the other
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
