Thanks Dave
I actually haven't tried mine yet. I expect they will be the same/same.
Will check the local specialised fixture n fittings and let you know if I find a permafix.
I have called dozens of RC/Hobby/caravan and even custom strut companies, no dice.
So I am resorted to going direct to manufactures but getting the MOQ to something manageable is difficult as most don't stock this size, which needs to be made.
Finally got around to fitting mine just now, work a treat.
Shoulder & head are now a little sore since I didn't have anyone around to hold to bonnet! Haha.
Thanks again Dave.
Changed my Cam Cover Seals today and greatly appreciated the extra headroom and all round access these things provide.
Love 'em. :woot:
:thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
