I have 2 sets for R32 GTR (not sure if fits R32 GTS-t, I cant see it not).
One opened for trial fit and one still packed as received.
Unfortunately I could not make them fit perfectly without a 3-5mm raise appearing just 'past mid way.
It's minor but I'm a perfectionist on my GTR.
Happy to on sell for same as cost.
Edited by Sinista32
  • 3 weeks later...
  • 3 weeks later...
Quick question, and I know its not really completely on topic. But is the supplier able to do boot struts as well? Ive been looking around and can only get them at a decent price from the UK, which is ok but just thought id ask the question here
  • 4 weeks later...
  • 1 month later...
