Can't lift arm above head = possible supraspinatus inflammation too. Don't agree with physio recommending you do deads again next week just to test the waters for aggravation. Way too soon after injury.
Correct movement shouldn't cause any aggravation
25/11/13
Squat
35kg x 10
40kg x 15
45kg x 12
50kg x 5
50kg x 4
45kg x 10
45kg x 10
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 8
60kg x 5
55 min boxing @515 calories
Physio wants me to do my normal program this week to help her gauge what I should do next but I decided to not do seated row and shoulder press because too painful.
So if someone has a broken arm, correct movement should suffice?
No Birds, and that is a terrible example in relation to what the physio would be trying to achieve. Unless the muscle is torn substantially, carrying out a technically correct movement shouldn't do any damage. - having a debilitating tightness/impingement and tear are totally different.
see below.
Like with anything, the more information known, the easier diagnosis can be. This may be a trial and error over a few sessions to guage what is setting it off.
Someone like Rev going to see a professional, which he probably never needs to because of his knowledge, would be a lot easier to diagnose than the average person going in with no real probable cause.
With around 700 muscles, it's not as simple as saying 'my shoulder hurts'
*This isn't directed at you either Leesh, just had to explain my comment for birds as he got his back up over someone questioning him questioning a professional.
The problem is, jangles, that I have heard first hand how badly agonizing this pain actually is for Leesh - it is not a simple impingement or tightness that one can work through just to aggravate it for the sake of a physio. She literally can't lie on her back and cannot continue the movement (or many other movements for that matter) after doing a deadlift, can't lift arm above shoulder, struggles to dress and shower...which is very worrying for me...both as her partner and trainer...so you can forgive me for telling her not to do the exercise and to rest up, so that any part of the injury that can heal with time, does, and then her physio can safely look at diagnosis. The problem may not even be muscular, which is where my greatest concern is.
Rev is the first to say himself that, in the case of injuries, such as rotator impingement, cut out the *bro press* or exercise responsible for it, and start working on rehab and strengthening the supporting muscles while you rest.
As for professionals, there are all kinds, and professionals disagree with each other. But if you want to assign the label to someone you haven't met, be my guest. I have seen some great physios; I've seen some terrible ones who know absolutely nothing about weight training and simply take advantage of time healing wounds in most cases. I think it quite dangerous to assign utmost credibility to someone's advice simply because they have a certificate and an ultrasound machine.
Physio has already diagnoised my injury as joint rather than muscular - thorasic spine T5 to T8 is where I am most injured and intervertebral discs
Depending on outcome of next physio session, I'm looking at booking an appointment with a sports medicine doctor because I would like to continue gym as I've just signed up at a powerlifting gym for 6 months.
27/11/13
Bench Press
20kg x 10
30kg x 10
40kg x 5
40kg x 5
40kg x 5
45kg x 0
45 Leg Press
80kg x 10
100kg x 10
120kg x 10
140kg x 10
160kg x 10
180kg x 10
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 7
20kg x 7
25kg x 1
Captains Chair
20
20
20
20
20
20
10
10
Knee Raises
20
Deadlift
60kg x 10
70kg x 5
70kg x 5
70kg x 5
80kg x 3
Ab crunches
200
Just taking it cautiously with my injury.
30/11/13
Squat
20kg x 10
40kg x 10
50kg x 10
45kg x 10
40kg x 25
40kg x 25
Pause Squat
35kg x 7
40kg x 5
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 6
65kg x 2
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 6
55kg x 5
Ab Crunches
250
30 min HIIT (grit strength)
10 min rowing machine
oh holy shit on the injury Leesh, that sucks! :( sounds a lot like some of the pains I was getting when I crushed my T5
Hi Troy, yeah probably very similar.. my injury is primarily T6 and T7
I took 3 panadol before physio yesterday and still had to get her to stop when she got to T6 :(
It's actually a bit less painful at the moment, hopefully I can sleep tonight... that's been the most annoying
02/12/13
Squat
20kg x 10
40kg x 10
50kg x 15
45kg x 20
45kg x 25
Pause Squat
40kg x 5
45kg x 1
Lat Pulldown
30kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 7
65kg x 4
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 5
Ab Crunches
150
100
30 min core/ab class
(physio recommendation)
45 min boxing @ 350 calories
Goals are taking backward seat as I'm still having issues with bench, squat and deadlift. Really I'm just grateful I can still exercise at the moment. Trigger point today which will hopefully ease some discomfort.
Edited by L33SH
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
