This is a last resort. Back hyper extension during deads
Bruised the nerve ? Can be tricky / take a while to fix. I hurt my lower back a long time ago , same/similar deal.
Stuff that is worth addressing that can speed it up that worked for me (you might already be doing this). They might help;
* stop working out muscles that pull the hip into rotation (back extension).
* Hip mobillity ; due to the injury you automatically have some muscle imbalance , you will find your hip flexors can shorten/tighten over time taking up the slack.
- depending on if you have lost flexibillity this will aggrevate healing.
**** there are some hip mobility tests on youtube , check it out then go for some stretches.
Eg ; Hip Flexor stretch done properly
* ditto for the upper quads
* Glutes (inc. Piriformis)
* ITB's
Stretch / foam roll them all.
Hope you get better soon.
  • Like 1
22/01/15
Bench Press
25kg x 10
35kg x 5
45kg x 3
52.5kg x 0
50kg x 1
50kg x 1
45kg x 4
40kg x 6
40kg x 6
20kg x 50
30kg x 15
30kg x 10
Close Grip Bench Press
25kg x 15
30kg x 10
Bicep Curl
15kg x 10
20kg x 10
20kg x 7
25kg x 3
25kg x 3
Captain's Chair
20
20
20
26/01/15
Squat
20kg x 10
30kg x 10
40kg x 10
40kg x 10
50kg x 5
55kg x 5
60kg x 1
50kg x 5
50kg x 5
50kg x 5
40kg x 15
40kg x 10
Pull-Up
9
6
5
Lat Pulldown
30kg x 10
35kg x 10
40kg x 10
45kg x 5
50kg x 5
Box Jump 60cm x 20
Box Jump 75cm x 20
One Leg Box Jump 45cm x 50
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
