Yeah I've cut out all junk food/chocolate. Cut down on alcohol to 1-2 glasses of wine a week. Cut out butter/margarine. I'm now cutting out coffee. Gone from 5 a week to one. Trying to drink 2L water a day. I'm having three low carb days a week, as I'm doing Hypoxi at the moment too.This is an example of my daily diet atm.
When I first wake up: ehp labs oxyshred with 300ml water
Breakfast:1/2 cup oats, 1/2 cup Chobani fat free Greek yogurt, 1/2 cup water, 1 scoop
WPI all mixed together
Snack: banana, 600ml water
Lunch:
Low carb day: poached eggs, spinach, haloumi
Normal carb day: museli and Chobani fat free Greek yoghurt
After lunch: 2 scoops WPI protein shake
Afternoon: 600ml water
Before gym: eggs on toast (no butter/margarine) water
Dinner: usually stir fry veg/quinoa/tofu/chickpeas/broccoli/spinach
BCAA drink with 600ml water
Maybe I'm still eating too much?
keeps tabs on your sugar intake and also which protein powders you are using. Cause a lot of those "low fat" yogurts (and foods in general) use a ton of sugar to get the flavour back into the product
Yeah true, I live on Chobani yoghurt, here's the nutrition info:
Not too bad imo?
Thank you :)
Nothing in particular. I give every training session 110%; however I'm probably able to focus more on my training this week due to no work stress, which helps with my back injury as I don't have to be standing up all day.
My partner in crime was having a good session which always spurs me on. I had to beat his last set of squats at 18 reps, so I did 20 [emoji14]
Some days I feel stronger than others, which can be attributed to so many variables: food/calories/carb and protein intake, sleep, hydration, hormones, menstrual cycle, gym recovery, mood, back injury, stress and energy levels. I never really know what it is. I try to keep as many variables as constant as possible, but some are out of my control.
Edited by L33SH
  • Like 1
10/10/15
Squat
20kg x 10
40kg x 5
60kg x 5
65kg x 5
70kg x 5
75kg x 3
80kg x 0
60kg x 30
60kg x 15
60kg x 10
Pull-Up
8
4
4
Captain's Chair
25
15
15
15
10
Lat Pulldown
40kg x 10
40kg x 10
40kg x 10
40kg x 10
19/10/15
Squat
20kg x 10
40kg x 5
60kg x 5
65kg x 5
70kg x 5
80kg x 1
70kg x 6
65kg x 10
60kg x 10
60kg x 10
60kg x 10
50kg x 10
Pull-Up
8
7
5
4
Captain's Chair
30
20
Lat Pulldown
35kg x 10
40kg x 10
45kg x 5
50kg x 5
50kg x 5
50kg x 5
  • Like 2
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
