did you notice much in the wing etc? a mate runs the same wing on his 33 and he said he noticed a fair bit of difference
kay, i see 2 seconds, massive
Edited by Mr. Untouchable
OMG this car is a TV star...they had coverage of the Winton Supersprint on SBS/ Speedweek today. Well done :)
:cheers:
Nice work Johnny.....loving it.
Looking forward to seeing the latest additions!!
Have you had it on the scales since its diet??
Always wondered what they actually weigh......my rego sticker says 1200kg.....paha!!!
Cheers,
Dave M
Haven't yet.
They are much heavier than 1200, thats for sure. Nissan says 1370ish from the factory.
I'd say it's 1300'ish at the moment. You can take a heap off metal and gear off it, but there has been so much added.
So the focus is firmly on World Time Attack in October. Then Winton/Wakefield come up with feeder state rounds. So it's on to improve the car in readiness for the Vic round.
Weight, removing the AC
And ducting between the intercooler and radiator
Adding a power steering cooler at the same time.
Changing the spring rates from 8/6 to 10/7, longer wheel studs
A change in wheel size. From 17x9 +22 to 18x10 +35, these needed a 5mm spacer on the front to clear the inside.
Also, the regs for Vic were a little stuffed and allow club cars to run r comp tyres.
So a set of 265 A050's in medium, my first try at an r comp tyre.
more powerrrrrrrrrrrr
change the stock intake pipe to a hard one and give it more boost. Also had to change the actuator from the stock one to a HKS 1 bar.
The little 21U won't hold boost up top and bleeds off to from 18 to 15PSI
There isn't enough time for parts to come in a put the diff back together before NSW Time Attack, so I raid my brothers daily.
Which has a newer NISMO GT 1.5 way (mine is an old NISMO mech 2 way). But is a non ABS housing diff.
So I'll be running NSW TA without ABS :huh:
At the same time the rear arms go off to pedders for polly bushes and new ball joints.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
