Hey guys,
First time poster, so let me do the quickest intro ever and say I'm Josh, 24, from Western Sydney, just bought my first Skyline (an R32 GTST), previously a 300zx guy...
Anyway, to the point, I was wondering if I could get some help/advice. I'm thinking that my Skyline may have a problem with the HICAS or something else steering-related. My steering wheel will be perfectly straight when driving at low speeds, say <50km/h. However, once I go a bit past this, the steering wheel will start to turn counter-clockwise. In other words, instead of the 12 o'clock position on the wheel being at 12 o'clock, it has now shifted to the 11, or even 10 o'clock position (whilst still going straight ahead).
This is really uncomfortable and is quite a nuisance, especially when accelerating hard. Surely it's not normal? Can someone please give me some advice on what I should do? Will HICAS elimination fix this?
Thanks in advance.
Edited by inmaniac
  • 2 months later...
Well mine was fine when I bought it..
Has a HICAS lock-bar though..
Could also need a wheel alignment? :P
I've been in my friends gtst (HICAS still present) and it feels like the rear end wobbles really bad going 100-110kmh on the highway but doesn't steer off when the wheel is let go..
I'm not 100% sure what Hicas does. But just say I'm driving in a straight line. The faster I go the steering wheel will start turning but I'm still driving straight .. Then when I'm slowing down the steering wheel will go back normal.
It's a odd feeling your steering wheel turning while your still driving dead straight under acceleration :/
A simple explanation of what HICAS does in a 32GTSt http://nissanskyline.6te.net/HICAS.htm
Take your vehicle to a steering and suspension shop and get them to identify and quote the issue in the front.
Not saying get any work done there. Just find out what your really dealing with first.
Edit:
I should have started off by saying have you looked at both sides up the front from underneath.
Spotted anything looking out of place. Given everything a good tug to see if anything is loose.
Edited by Sinista32
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
