After the last EOI (http://www.skylinesaustralia.com/forums/topic/416591-eoi-simworld-2013/#entry6688024) died I'd see if we can organise another SimWorld event!
So - We (SAUWA) is thinking of holding another Social Event at Simworld in Carousel after the huge success of the previous events. Everyone had a great time at the last couple events although there have been a couple inflicted with motion sickness so its quite a ride
For those who don't know what SimWorld is check it out at http://www.simworld.com.au/ These are full simulators, where you get thrown about etc, nothing like anything you've done before.
The general format of the event is:
Group 1 - 5min Practice - Course 1
Group 2 - 5min Practice - Course 1
Group 1 - 10min Race 1
Group 2 - 10min Race 1
Group 1 - 5min Practice - Course 2
Group 2 - 5min Practice - Course 2
Group 1 - 10min Race 2
Group 2 - 10min Race 2
Group 1 - 5 min practice - course 3
Group 2 - 5 min practice - course 3
Group 1 - 10min Race 3
Group 2 - 10min Race 3
Final - 15min Race (combined results from Race 1, 2, 3 & 4 will determine who is in the finals)
* Minimum race time should be about an hour
** Comes with food supplied by Nandos or we can have pizza plus we can have BYO drinks
*** Group size is 9, as there are 9 Simulators
Note:
The costs approximately $65 if we choose nandos or pizza or $50 without food but I would imagine majority will want food so everyone will have to pay $65
The a full race simulators, not simple arcade games, so it will definately be an experience.
Friday nights we will get the longest time on the machines for our money and its been convenient for most people in the past. Maybe the 13th or the 20th of September might be a go-er?
Please register your interest ASAP, so we can make this event happen. Please invite family members (friends, wives, older kids etc), as all Simulators are equal, and doesn't require a drivers license We'd like to have this filled with SAUWA Members and there familys/friends, but seeing as we didn't get enough interest I'll open it up to the rest of SAU from the get go.
So far
* Trevz
* Lachy (Hank Scorpio)
* Gary
* Damo (Frosty)
Cheers
Hank
Edited by turboedsloth
https://www.sau.com.au/forums/topic/429982-eoi-sauwa-simworld-racing-night/
Btw hanky they didn't have skylines available last I heard
:O
What happened to our R34 race at Tsukuba!?!
Anyway I'm confident of numbers now, will try and contact SimWorld this week :)
Sorry about the lack of replies guys, that's completely my fault, I do apologize.
http://www.simworld.com.au/contactus.aspx
"We have moved the machines down to the Albany Amusement Centre (formerly Albany Ten Pin Bowling)"
So SimWorld seems to be a no go, any other ideas you guys would like me to look into?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
