Hey guys I'm from Sydney but came across a listing on eBay this guy who has probably a full truck load of parts from 32/33 Gtr's he wants 2-3k for the lot and its kinda hard without seeing it. Anyone feel like having a look for me ? He says 20 mins from Melbourne
Scott
Yep I get them...
XXX: This guy is a user on SAU and ripped me off
Me: Ok where did the transaction take place?
XXX: Ebay
Me: So what do you want me to do about it exactly?
XXX: Ban them or help me
Me: Sorry it's not a SAU based action of any kind, i really can't do anything
XXX: Oh well f**k you then for not helping me out
I get it ALL the time.
Yep I get them...
XXX: Ebay
I had an over cooked steak ages ago, I want you banned because you are a part owner of squires loft
Yep I get them...
XXX: Ebay
Hey ash,
I got cut off on the way to work by an Asian this morning. Subsequently I'm requesting that Alvin be banned because he is also asian.
Thanks
  • Like 1
Yep I get them...
XXX: Ebay
LOL!
Because you're Superman and you know exactly where and who they are on ebay...
And since you're Admin / Mod, they must think you have some kind of gigantic super matrix computer that sees all in the cyber world...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
