A good tuner probably won't touch it with the SAFC. Pretty sure Trent won't.
Have a ring around perhaps, I would say most tuners will try and talk you into an emanage Ultimate at least.
I thinks he lives in punchy brah
I'd call around and see who's done safc and ign on an rb. Or jump on Facebook and ask a few groups. Word of mouth from people is always better than a shop telling you they can do something.
Any tuner should be able to tune a SAFC and SITC. I had both plus a Jaycar boost controller which my local tuner hadn't seen before and he was able to tune for my GCG highflow.
I should say that I have had it tuned. Its currently on 160 all wheels with a bit of a dip up higher as the power builds and the occasional boost cut on colder mornings. I will be converting to manual soon and will want to tune again after that. That's why I am asking for recommend tuners. Thanks guys
