Hi guys,
I've looked at existing threads on servicing the V's...but my query relates specifically to the V36 370 - hence why I am starting a new thread.
A friend of mine wants to buy a V36 370 S model (coupe, auto, 2007/8). He is concerned about servicing costs and practicality.
Please note - he has no mechanical aptitude, does not want to be self-servicing, or even having to source parts. He'd like to think that he can rock up to Nissan dealership or Ultratune (or similar) and get the car serviced.
Given the stipulations of the V36 370 service schedule - is this a realistic expectation?
can any members who do or have owned the V36 370 coupe speak directly with regards to their personal experiences? What I would like to know is;
1. Is servicing the Skyline essentially the same as the 370Z – in terms of who can do it, what it costs, parts required etc
2. Is the ECU the same (by and large) as what is in the 370Z – such that a ‘normal garage’ could tune it?
3. Could servicing be done by (say) Nissan, or Ultratune, or an average mechanic
For reference, my friend lives in Traralgon – so a big country town, with Nissan dealership and Ultratune, but no performance workshops nearby.
Any assistance would be appreciated.
Cheers,
Foibles
Same engine as 370z
Nissan dealership can service them if they want to but alot of them will say they won't touch an import. You can tell them to just follow the service schedule for 370z.
One thing I've found different is that the 350z and 370z is the throttle body is different to the Vs...but in Japan and America they are suppose to be the same.
That said the ECU in Japan and America has the same ECU for the V/G and Z. Tuning can be done only with a reflash. Uprev is a popular reflash people use.
If go with specialist to service the car.
1). Yes
2). Almost all Nisan dealers won't touch a V35/V36 with a 20 foot pole - they HATE grey imports.
3). as mentioned you cannot 'tune' the stock ECU - if you get a Cobb or Osiris unit you can reflash the ECU, but you really need a local tuner skilled with Skylines to do this.
But the basic servicing any idiot can do - drop the oil then refill, clean the air filter element, top up the coolant. That's about all you need to do in terms of regular maintenance.
As mentioned, you don't 'tune' a car these days as part of a regular service, like you did in the old days of carburetors, points and weight type advance. These days they just check the ecu for any fault codes during a regular service.
Given they are essentially the same as the G37 being brought in by Nissan Australia, I'd say there shouldn't be any need to draw parallels with the 370Z any longer as the dealerships (those who will touch a grey import) will be trained to know these vehicles as well, I would think.
Get your friend to do the homework and if he isn't confident in servicing the vehicle himself or he can't find anyone reliable in his country town, then tell him to either take the risk or find something else. Otherwise, as already mentioned, any idiot can drop the oil, replace the filter and spark plugs where necessary - once you show them. Be sure he stocks up on copper crush washers for the oil sump drain plug as it's wise to replace that washer with every service.
Repco service agents, if they can be bothered, can access the Repco NZ files that cover the servicing and parts for Imports. The local one in Berwick did, when I had my R33 and the one in Officer needed NZ files for the M35 for brake specs etc. when they did my roadworthy.
There is nothing hard about maintianing or servicing a 370GT, all the consumable parts (filters, brake pads etc) are available from ryco, bendix or nissan. Any compident mechainical shop should have no trouble with this car.
  • 3 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
