It was without but we did the same test a few weeks back and got the 150-160
I'll give everyone a break down of how I did the test and I don't think throttle matters in this situation.
-Unplugged injector plug.
-Removed all spark plugs/coils.
-Got the compression tested and wound it into the cylinder.
-Turned the key over until it reached peak PSI and then stopped.
-Recorded said PSI and moved onto the next cylinder.
This sounds good. ^^^
Batty was definately down by a couple of Volts, but turn the engine fine, Headlights worked etc...
How was the car last driven?
Easy duties or Fully Thrashin' it?
I think we have to admit it couldn't throw results that bad.
To go from something like 160 to 25 is a massive drop.
Then for the cylinder tested after that to be 90 just wouldn't make sense.
Also we tried to jump start it and it wouldn't start so the battery is not the problem haha.
dont stress to hard till you do it properly. charge that battery to 12.6v make sure you.threads are clean for each cylinder and that the compression tester is seated and tight on each plug. make sure the cylinders are not completely dry using a few drops of oil or injectors still plugged in.
have to eliminate variables to get solid results.
same with jump starting, rating of leads, clean connections on both problem and donor car, donor car raising the revs to 2kish when trying to start, also problem cars voltage cant be too low either as it still wont kick. (not everythings black and white)
If your engine is cold, then you are going to get really low compression test results. I tested my car the other week without warming it up to operating temperature and got really low CT results, ~120 psi. It had me worried, but it should be around ~160 when it is warm and the tolerances have tightened up.
Edit: Didn't see the 25. thats a bit too low
Edited by chus13
Head gasket?
check for oil in water and water in oil
You could do that in a few hours if theres no head warping, trojan prob have a gasket on the shelf
re test for sure
Edited by D.I.Y. Mik
those numbers are too low double check that the tester was sealing correctly or that there isnt something wrong with the tester (try it on a known good engine), also compression tests are done with the throttle completely open (foot to the floor).
stick the battery on a charger or do the test with jumper leads connected to another car so it has some decent volts while testing.
Thanks again guys
Okay so I'll try a re test tonight and do it with open throttle. Also stinky if you are free this afternoon that would be great if you could swing by with some r33 parts and jumper leads?
If not I could borrow a car possibly and come borrow parts off people :)
Already got a tool box off Bryce and comp tester off Verms haha
Timing belt has not been changed since I have owned it. And I have had it for about 45,000km
Not sure when it was previously changed
What would happen if that was to break?
Does it still do huge damage at idle when something like that happens?
Timing belt breaks > nothing governing camshaft rotation > pistons mash valves.
If your timing belt broke you'd probably have heard horrible sounds as the pistons slammed into valves, rather than it just conking out like you indicated.
I'm still thinking something electrical...if the timing belt snapped and it mashed valves, given one cylinder is significantly worse than the others I'd like to think there should be at least 1 cylinder that reads almost normal (valves closed and intact)
Dude im sorry to hear that. I thought the same thing when we tested my engine, running ZERO PSI on 2 Cyl and about 10-20 on the other four. It's a shame i didn't take photos of what was left of my pistons when the engine was pulled apart.
Honestly id just pull the head off and check it. Hopefully its a gasket but it sounds like something more important. Just get a $1500 engine and swap your parts over. Maybe even find a whole 33 for like 2-3k so you have a full parts car.
I'm hesitant to suggest gasket as it'd be a bit unlikely to fail across every cylinder wouldn't it? I'd have thought once it blew the weak spot out, that's it and only the cylinders that needed that bit of the gasket to seal would show low compression....also if it failed on this scale, you'd be guaranteed water in the oil system and visa versa.
I should point out everything I suggest is just speculation. I've never dealt with engine failure or anything close to this scale of fail, so I'm just relying on my firm grasp of internal combustion engines and what effects what, particularly with RBs :)If I wasn't such an academic failure through school (thanks to giving almost literally NO f**ks for it), I'd be a pretty bloody decent mechanical engineer lol....just the way my brain is wired....unfortunately I'm just lazy and have next to no attention span for things that don't interest me :(
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
