It was without but we did the same test a few weeks back and got the 150-160
I'll give everyone a break down of how I did the test and I don't think throttle matters in this situation.
-Unplugged injector plug.
-Removed all spark plugs/coils.
-Got the compression tested and wound it into the cylinder.
-Turned the key over until it reached peak PSI and then stopped.
-Recorded said PSI and moved onto the next cylinder.
This sounds good. ^^^
Batty was definately down by a couple of Volts, but turn the engine fine, Headlights worked etc...
How was the car last driven?
Easy duties or Fully Thrashin' it?
I think we have to admit it couldn't throw results that bad.
To go from something like 160 to 25 is a massive drop.
Then for the cylinder tested after that to be 90 just wouldn't make sense.
Also we tried to jump start it and it wouldn't start so the battery is not the problem haha.
dont stress to hard till you do it properly. charge that battery to 12.6v make sure you.threads are clean for each cylinder and that the compression tester is seated and tight on each plug. make sure the cylinders are not completely dry using a few drops of oil or injectors still plugged in.
have to eliminate variables to get solid results.
same with jump starting, rating of leads, clean connections on both problem and donor car, donor car raising the revs to 2kish when trying to start, also problem cars voltage cant be too low either as it still wont kick. (not everythings black and white)
If your engine is cold, then you are going to get really low compression test results. I tested my car the other week without warming it up to operating temperature and got really low CT results, ~120 psi. It had me worried, but it should be around ~160 when it is warm and the tolerances have tightened up.
Edit: Didn't see the 25. thats a bit too low
Edited by chus13
Head gasket?
check for oil in water and water in oil
You could do that in a few hours if theres no head warping, trojan prob have a gasket on the shelf
re test for sure
Edited by D.I.Y. Mik
those numbers are too low double check that the tester was sealing correctly or that there isnt something wrong with the tester (try it on a known good engine), also compression tests are done with the throttle completely open (foot to the floor).
stick the battery on a charger or do the test with jumper leads connected to another car so it has some decent volts while testing.
Thanks again guys
Okay so I'll try a re test tonight and do it with open throttle. Also stinky if you are free this afternoon that would be great if you could swing by with some r33 parts and jumper leads?
If not I could borrow a car possibly and come borrow parts off people :)
Already got a tool box off Bryce and comp tester off Verms haha
Timing belt has not been changed since I have owned it. And I have had it for about 45,000km
Not sure when it was previously changed
What would happen if that was to break?
Does it still do huge damage at idle when something like that happens?
Timing belt breaks > nothing governing camshaft rotation > pistons mash valves.
If your timing belt broke you'd probably have heard horrible sounds as the pistons slammed into valves, rather than it just conking out like you indicated.
I'm still thinking something electrical...if the timing belt snapped and it mashed valves, given one cylinder is significantly worse than the others I'd like to think there should be at least 1 cylinder that reads almost normal (valves closed and intact)
Dude im sorry to hear that. I thought the same thing when we tested my engine, running ZERO PSI on 2 Cyl and about 10-20 on the other four. It's a shame i didn't take photos of what was left of my pistons when the engine was pulled apart.
Honestly id just pull the head off and check it. Hopefully its a gasket but it sounds like something more important. Just get a $1500 engine and swap your parts over. Maybe even find a whole 33 for like 2-3k so you have a full parts car.
I'm hesitant to suggest gasket as it'd be a bit unlikely to fail across every cylinder wouldn't it? I'd have thought once it blew the weak spot out, that's it and only the cylinders that needed that bit of the gasket to seal would show low compression....also if it failed on this scale, you'd be guaranteed water in the oil system and visa versa.
I should point out everything I suggest is just speculation. I've never dealt with engine failure or anything close to this scale of fail, so I'm just relying on my firm grasp of internal combustion engines and what effects what, particularly with RBs :)If I wasn't such an academic failure through school (thanks to giving almost literally NO f**ks for it), I'd be a pretty bloody decent mechanical engineer lol....just the way my brain is wired....unfortunately I'm just lazy and have next to no attention span for things that don't interest me :(
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
