Can anyone shed some light on what the next steps should be?
I was thinking
-hook up jumper leads and do another test.
-pull off the timing cover and check the belt
Then if stinky comes around this week.
-Try a new VCT unit just in case if he has one.
Anything else?
yes that is what I would do.
Redo the compression test while hooked to a running engine by jumper leads
When stinkypoo drops by, swap the ignitor, CAS, AFM and ECU (one by one) and see if it makes a difference.
If still crappy results and no luck, take the timing cover off.
Timing cover is like...3 bolts isn't it? The upper half of it at least. It'd take no time to pull off and look at the belt, should be blindingly obvious if that's the problem lol.
I'd check the things that take the least time to do first.
true. I'm not sure how much work it is on a stock 25...on a 26 it needs CAS off, water line disconnected (possible re-bleed) and then about 3 bolts. not a big deal. You should either carefully mark the CAS position before removing it, or redo the base timing after.
Yeah so I can't swap out an ECU which is a bit of a pain because its a nistune R32 ECU.
Using the Window switch (Not the jaycar one) its the proper window switch.
Checked that last night and it seems fine.
Rob pulled out the ecu and re connected just to be sure.
Yeah I will re run the test tonight hopefully ( is it okay to use a jump start pack thing?)
If it's easy to pull the cover off then I will check that as well.
Hopefully stinky has time to stand in the dark and cold with me and try a CAS or maybe even see something I am not noticing.
Daniel - pm your addy and I'll drop around a fully charged Battery, a Jump Pack and Jumper leads after work.
Edit: Oh and a battery charger :)
If tonight was like last night maybe drop off a few jumpers as well :P
LONG LIVE THE RB!
So I had a few of the locals come around tonight. Shout out to "Stinky Poo, Sinister & Wilderboy"
They brought along a jump starter and we decided to do another comp test with a starter pack giving it power.
Cyl 1 = 95
Cyl 2 = 90
Cyl 3 = 80
Cyl 4 = 105
Cyl 5 = 95
Cyl 6 = 100
Sat around and pondered the idea about costs doing an engine swap or just giving up on the dream
But Stinky Poo (Don't want to f**k up the spelling to your real name) Decided he wanted to put it back together and give it one more chance.
We put everything back in and back together and the farken bitch started first go!
Didn't even miss a beat!
Right now I'm left scratching my head as to why the compression is still so low (could it be possibly the tester itself?)
and left wondering why the car just decided to start again for no reason.
Leaves me worried I'm going to get stranded somewhere I don't want to be.
My next step is maybe take it to a workshop for them to triple check everything.
  • Like 1
Thanks to everyone for all the help over the past few days!!
I really really really can't thank you all enough!
Glad this didn't make it to page 10
Long live the RB!
And yes a warm/hot test will be a good comparison because it can be lower when cold right?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
