Hey guys :action-smiley-069:, after seeing all these EPA blitzes around Melbourne I think it's time I take the cannon off as it's just far too loud. I have another cat-back sitting in the shed but the problem is that though it's all nice and stock, the tip is one of those pea-shooter types so it looks sooo crap. So, I was wondering whether it's possible to cut a section where the tip is and weld on a chrome twin tip? If so, would anyone be able to help me out or know someone reliable who could do the job? I'm in the south-east suburbs (Rowville) and am willing to pay!
Cheers! :cheers:
Abz
https://www.sau.com.au/forums/topic/430647-need-some-help-please/
The only issue with old stainless systems is they need to be cleaned very well internally before welding, as carbon will contaminate the weld. Mild systems are even worse as you have rust to deal with.
For a cheap job any exhaust joint can mig a tip on it for you, if you have any issues finding someone reliable though, or you want a better quality job you can try dropping me a PM to see if i'm free sometime...
this man. he is the shit. ^ pm him now.
PM'd :D
yeah meng I had that same set up as you, just kept a epa friendly pea shooter in the shed (looked so crap) but my cannon (kakimoto racing zorst) was just far too loud at 112db. :( this one looks clean and sounds good too and doesn't hurt my ears. ^^
Glad you're happy Abz, I was actually surprised how quiet the system ended up being, for two straight 3 inch mufflers. That should keep you out of trouble with the epa, if the rumors are true they will be cracking down in December with mobile detection setups. :unsure:
Got my zorst done. :D Many thanks again to #scotty nm35 great quality work! Oh and that NM35 is a bloody rocket, my head's still spinning :P
I just found out that this is my old muffler! Lol good to see it being put to good use
Cheers mate :) so much better now and i'm getting a good RB noise :D but nothing compared to the experience of your stag :P
haha i bet your old one must have been droney as fuark then! i know my old one was... i dunno how i lived with it for as long as i did :P
new exhaust looks good :)
Thanks man! :) yeah it was drony as fuark, I took it to reefton a couple of weeks ago with some rx8's apparantly it spat flames a few times at high revs :O but yeah took two days to get rid of the drone headache. :/
Haha thanks for the muffler :P Which car did you have it on?
on my 200sx. lol it sounded nice - cleaned up the tractor sound nicely lol. scott was getting angry at me that i left it there lol so thanks for taking it lol
Haha nice, certainly sounds good on the dirty4 too and lol you're very welcome :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
