Hi all,
Just bought my brothers r33 gtst which is hunting whilst driving or idle..
It was blowing some black smoke which has stopped since replacing the fuel filter, spark plugs and oil filter/oil.
At the same time the hunting stopped so i thought i had fixed it however today it started again....
I am sus to it being the coil packs ?? (does this sound like a possibility?)
didnt want to pointlessly buy some so was wondering if anyone in Penrith/western sydney has any i could try and see if they fixed the problem?
https://www.sau.com.au/forums/topic/430698-r33-gtst-hunting/
Hunting during idle is typically due to additional air getting into the system which the air flow meter isn't registering. This is due to a leak somewhere.
The most likely culprit is the black charcoal box that they have to install when importing for emissions reasons. One of the hoses that comes out of this feeds back into your plenum. If you plug the hose with a ball bearing and the hunting stops you've found your culprit. Other points to check are the multitude of vacuum hoses that run around the engine but you don't often see these leaking.
  • 2 months later...
OK guys, reviving a bit of an old post, still having issues...
symptoms:
Car is hunting (not always) on idle...
when driving there is a miss (sometimes not consistent)...
when driving revs cut out completely but the boost gauge on the dash says its still on boost (do not need to be driving hard - intermittent)...
Fix Attempts:
Cleaned the AFM
Cleaned the AAC Valve
Changed Spark Plugs
Changed Fuel Filter
Changed Oil Filter
Changed cracked vacuum hose coming off of the plenum (just above the aac - went back to a black box)
Plugged above hose after changing it didnt help
New genuine o2 sensor
I'm out of ideas, the only thing i have yet to try would be coil packs but dont want to spend all that money and it not be the problem. any other suggestions?
symptoms:
Fix Attempts:
Cleaned the AFM
Changed Spark Plugs
Changed Fuel Filter
Changed Oil Filter
The miss could be caused by the coils, but I am not sure if it is causing the hunting. If the car has done well over 100k kms, the coils should be changed anyway. A set of splitfires set me back $400 and were easy to install, and should last you another 100k kms and will last with any mods you plan on doing.
Like Plattsy said, try a ecu reset. Although I didn't think it needed to be off for 24 hours, I would have thought 20 mins would be enough.
you can do it in twenty if you pump the brakes or some shit. but i always left it for a day to be sure.
Tried the ECU now, no good still the same. the annoying this is its not consistent, at first it ran well but shortly after started having the same issues. Any other ideas? I was thinking due to it being intermittent it might be some sensor or electrical fault?
OK, car ran good for about a week, played up again, ran good another 2 days, played up and now seems to have a constant issue of the car starting to drop revs when i go above 2500 RPMs in any gear. If i stay below the 2500 the car is running fine.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
