Hey guys,
I have a strange issue with my RB25DET. It seems to have a weird fluttering/wooshing sound when coming on boost, a lot louder than normal. It seems to build and hold boost ok, maybe a little laggier than usual. I'm thinking maybe a boost leak, but here's the spanner in the works: the weird wooshing sound disappears during medium-hard left turns?? How weird is that? Does anyone know what could cause this issue and why it disappears during left turns only???
Any help appreciated. Thanks.
https://www.sau.com.au/forums/topic/430790-weird-boost-issue-help/
After the sound got worse I eventually found the problem - broken stud where the dump bolts to the turbo, letting a heap of exhaust through the gap. Now I have a worse situation than a boost leak, the stud is broken inside of the turbo exhaust housing and I need some way to get it out...Preferably without removing the turbo >_>
Trust me - I had the same problem last year... Take your turbo out and take it to a thread doctor or machinest... If you do it yourselves I can guarantee you'll ruin it.
Try removing the turbo yourself - if you need help just post on here and I'm sure you'll get plenty of help!
There are many brands. Just go into any hardware or auto parts store and see what they sell. Loctite do one, as do many other big brands. We use one at work with graphite in it and it seems to work well (although it's a bit messy). I have a can of stuff somewhere that I got when I was working at an exhaust shop that we used to use there which worked well too. If I can find it I'll post up what it is.
Thanks for the info.
The thing is, I can go and buy another brand, but if it works just as well as WD40, is there any point in paying more for it (if it costs more)? Hopefully the other brands can provide a stronger product, or one that lubricates better.
The graphite stuff sounds good.
Wd40 is only really a water dispersant and thin oil. It has very little in the way of actual lubricating properties. You can find some friction test videos on YouTube. If you search "friction master wd40" on YouTube there is a 2:36 long video of a test between protecta spray (which I've used and it's pretty good) and wd40. Protecta also have a video on YouTube doing the same test with more oils. I know the guy doing the protecta video and he told me about some other lubes that performed well on the test (almost to the level of protecta), but they didn't show them for obvious reasons. They were bicycle chain lubes though, so not much use for anything else.
Fyi, I am in no way affiliated with protecta.
And using some sort of grease or anti-seize paste when installing things certainly makes life easier in the long run.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
