Nisasn want $280 for an R32 GTST O2 sensor. That sucks.
I'm hoping the R33 S1 O2 sensor is the same.
Graham West Dyno down in Adelaide apparently knows what aftermarket o2 sensor to use with the rb20det's. He quoted $130.
Edited by Cubes
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1792513
So i just read the whole thread....
So coinfusing... People saying different things...
I currentlly have bosch 3 wire white/black/white
and i have bought an aca rox207
which has black/black/blue...
Im gonna hook up like this;
Nissan Ford
white------black
black------blue
white------black
Is this right???
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1793618
So your telling me after 21 pages you guys haven't figured out what is a cheap alternative to the stock sensor ... :(
I thought you would be able to get any sensor suitable for a turbo with same thread pattern..all 02 sensors read 0-1v and have a simlar "narrow" band of operation
Thats rough
Edited by benl1981
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1793630
Ok.... instantlly heaps punchier....
After the engine warmed up it got really tweaky....
No excesive fuel out the back when i boot it....
Seem to be spooling sooner but not as hard at the top end....
Fuel will take time to figue out if its better.... As i was punching it heaps today hence a big drop in fuel....
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1796124
The 02 sensor doesn't affect what you have imagined. :huh:
The 02 sensor is used to tweak afr's at light throttle cruise.
The ecu ignores its output once you stick your foot in to it.
Anything more than limping around it will turn off and use the values from the map within the ecu.
Edited by Cubes
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1796280
Well thats what happened....
Seems to be using more fuel at this stage... But yeah as explained its more punchy and is not spewing fuel out the back...
I understand the function of a 02 sensor and have a apexi tt which measures and monitors o2 sensor voltage...
It changes all the time... Your ecu always reads the o2 sendor... Under full load you can reach around 4.3 volts
Idle you get down to 1.2v...
Either way you wanta look at it... The fact remains that it is smoother due to the old one not being able to read more than 3volts....
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1796947
Yer your way off Col-GTSX. Go back and do some more reading/googling.
Sorry Buddy. :D
The O2 sensor operates between 0 and 1v and trims the ecu's internal fuel map so the afr hangs as close as possible to stoich (14.7:1).
It can only trim so much, so if you raise fuel pressure or run larger injectors you will find it will simply not work and constantly idle and cruise very rich.
Should the o2 sensor die the ecu will run off the ecu's internal fuel map that is generally slightly on the rich side BUT within the o2 sensors capability to trim enough fuel out to bring the afr's to stoich.
1v being rich 0v being lean. From memory 0.9v is somewhere around 12:1.
The ECU only uses the o2 sensors output at light throttle positions. Nothing to do with wot so it WILL NOT make the slightest difference to fuel spewing out the back.
My RB30DET drops out of closed loop just after the TPS reads 1v.
1v is bugger all when it comes to throttle positions. It does vary slightly but almost always very close low 1v. This is the TPS (Throttle position sensor).
The highest I've seen the o2 sensors voltage hit on the pfc h/c is 1v at approx 4000rpm on the untuned rb25det pfc base map at WOT.
When it does this I do see fuel out the revision mirror if I catch it at the right time.
To help you understand the workings a little better you can have a look at a few datalogs I have taken via the datalogit a few weeks back.
Thats if you wish. :(
Edited by Cubes
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1797433
I just given you the results...
I dont understand how it could change it so much...
Im just telling everyone what happened on my car... Checked with a volt meter
Yes it goes up to 4.3 volts...
Not saying i know more than you i just know whats happening on my car at the moment....
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1798470
col i've got the exact same o2 sensor as you... the rox one..
when you test it with a volt meter thingy your testing it at the actual wires coming off the o2 sensor right ??
is it possible you got the wrong o2 sensor ?? if its showing more than like 1v and your testing it at the actual o2 sensor it sounds like its not the correct sensor ???
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1798518
col have you got another sensor to test ??
it sounds like that one isnt the correct one..
It doesnt sound right that it could be something in your car stuffing up the o2 reading if your getting the wierd reading from the wires coming off sensor its self..
also i dunno bout that ox-207 one.. I know mine was rox-207 if that makes any differance......
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1799155
LOL LOL LOL LOL
I made a boo boo...
I was actually testing from the ecu using a power meter in conjunction with my ID-III and it was showing afm voltages....
HAHAHAHAHAHA
The O2 sensor is fine.... Reading less than a volt... Very frequent changes between .3 & .6 area.... So my bad...
As for my results, they still remain the same...
NOTE: I am using more fuel but the new fc tune ill request for a nice easy tune not an outright power tune...
If i want speed ill jump on the R6....
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1799769
  • 1 month later...
hey guys just changed my o2 sensor with the rox-207 one....car started perfectly straight away unlike alot of people?...
i was getting about 280-320 km's out of a tank...ill let u guys/girls know how i go in a week whan i use a full tank.....hers hoping 400km's :)
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/8/#findComment-1910078
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
