I'm after new O2 sensors for a Stagea 260RS (R33 RB26DETT) and judging by James' page (great page James) there is a Bosch alternative. I'm not a fan of cutting and joining wires. I wonder if the pins on the plug it comes with can be removed and put into the stock nissan plug. ANyone tried?
yes thats exactly how we did it. remove and replace the pins from the factory plig for the rear o2 sensor
Good stuff! Do you know which sensor it was that you ordered? Was it the Bosch one that's listed on James' page or something else?
Cool, thanks Duncan. I've got onto Global Spares to get two of the sensor quoted for the front. Let's see what they come up with..
Cheers
I read every page of this thread and found one post I think from a pilot who quoted a price of $256.00 for the pair of r33GTR o2 sensors, I think from Global auto spares,but I can't find it now ,anyone see that.Grey Pearl.
Further to my last post I rang Global Auto Spares and the numbers that keeper gave us for the GTR33 O2 SENSORS APPEAR TO BE WRONG,probably because the guy at global gave him the wrong info.
Apparently the correct global order no info for gtr33's is front:351-0019 $77.00 and rear 351-0019a $145.00 and apparently direct fitment no need to change plugs or wiring.Can anyone tell us if you have bought these items from Global and they fit??Cheers Grey Pearl.
That part number is the same as what James has listed for the R32 GTR. If I'm not mistaken, the R32 uses a small size thread than the R33. I guess you could get one of those adapters. They're both Titania though aren't they (correct me if I'm wrong).
I really don't know I just quoted the part no's that keeper gave us and questioned Global over it as much as I could before he said he was too busy and had to go.He said it was definately the right fit up for gtr33 but now that you say that the numbers are the same as for gtr32 I know it's not a direct fit and now wonder which ones Duncan has been using for gtr33's.Cheers Grey Pearl.
33 gtr is the larger thread and 32 gtr the smaller. they output the same voltage so they are interchangeable - the ones you need depend on the dump pipe you are using, and most (all?) aftermarket dumps take the r33 size fittings.
ngk part # for r33 is OTD2F-P1P. direct fit for front sensor (3 pin plug).
They incorrectly show the same part# for r32
  • 3 weeks later...
I have asked this in another thread
http://www.skylinesaustralia.com/forums/Ro...Ne-t223543.html
- but does the NGK O2 sensor for the R33 fit the R34 RB25DET Neo engines? appears it might but no one has 100% confirmed this in this thread...
Also could the air flow sensor also cause rough idle and high fuel consumption or is this purely the O2 sensor failure that causes this?
I have changed the Spark plugs already and the oil...
Amongst many other things, a rough idle could be the AFM itself, or an inbound air leak past the AFM. This particular problem (not saying this is yours though) is unmetered air passes into the system and the ECU is out of whack because [AFM recorded air flow] \= [actual air flow]
Fuel consumption is prob O2 sensor. From memory, if the AFM is stuffed, the car will have trouble even idling properly, let alone causing high fuel consumption. My experience is with RB26 though, so when one of my AFMs died the car could keep running.
FWIW.
Ok confirmed 100% wrong connector on the NGK O2 sensor for use with the R34 - I will solder the existing connector onto the sensor and hope it works...
BTW - my existing O2 sensor had a stack of black soot on the tip - what would this tend to indicate?
Well the NGK connector is light Grey and more solid looking with all the spade pins Vertical and positioned in the center of the connector. The R34 or BOSCH connector is black, maybe a fraction smaller and all the spade pins are Horizontal and thinner and positioned in the top area of the connector.
Might take some shots if I get around to it...
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
