Hey guys,
I recently put a heavy duty button clutch into my car last weekend, and am playing on taking it to an event this coming weekend.
I've been driving it as much as possible, but is there a quick way to bed the clutch in?
I have a 3hr drive to the track tomorrow night but it is mostly freeway. Should I consider pushing the clutch in and out occasionally as I drive? Change between more frequently 4th and 5th? Or am I going to do more harm than good?
Thanks.
https://www.sau.com.au/forums/topic/430998-quickly-bedding-in-a-new-clutch/
I would have thought a couple of days of driving in city/traffic sufficient. After a 100 or so kms again I would think all is sweet.
PS. Stay away from riding it for a short while immediately after fitted. Being a button clutch if you ride it will heat up the button easily.
Glazing can occur also.
Edited by Sinista32
In my last car (R31, RB30 engine, RB20DET box) I took my car drifting and was used the clutch as I normally would after a couple hundred KM of normal driving, no problems at all. I just did the same thing with my S14 (SR20 engine, RB25DET box) with no issues - it's all you need imo!
First clutch was an Exedy sprung brass button with an upped (1350kg) clamp load job, S14 clutch is an Exedy Sports Organic (coppermix-ish one).
im in a simlar spot my clutch is only new only done 200km maybe if that - no launches but have started to open up 2nd and 3rd clutch is still bedding in can smell it if i flog it but npc said that will happen for maybe 500km but said if i dont get enough km down the when i get to the track to warm it up and it should be fine..
dont like bedding it in special whe you can smell it but npc said its normal (was my first clutch change)
I didn't smell either of my clutches when bedding them in, I wound out 2nd gear to redline in my S14 with about 70km on the clutch too.
i got npc cushion button clutch rated 450kw.. what was your clutch and your power?
i been told it is normal so lets hope so gonna get a flogging soon hahaha
My current clutch is an Exedy Sports Organic HD - it's silver, not pink like many other Exedy clutches and has a coppermix sort of compound - like a poor man's Nismo Coppermix haha.
My power is dead stock, SR20DET.
My previous clutch was a bit of a mix, it was a 6 puck sprung brass button clutch (Exedy) but K&B Clutch Engineering in Sydney modified the pressure plate and increased the clamp load to around 1300kg. That was used with a stock RB30E, no smell either.
Both very low power applications.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
