So im looking at purchasing a set of cams and iv come across these camtech cams. Has anybody heard of them? Anybody Using them? opinions will be much appreciated. Also what cams does everybody recommend using in a stock bottom end RB25 with a GT3076 .82. Making 300kw now on 16/17psi will be upping the boost to 20+psi when i decide on cams and wont be using the VCT.
Cheers, Phill.
https://www.sau.com.au/forums/topic/431071-camtech-cams/
How would 268 go on a 3076? im looking at the 264 in/ex 9mm lift.
Any advantage of leaving the VCT? wouldnt the vernier cam gear (when adjusted) be better?
Im no expert, so take it with a grain of salt, but i think they are to big and suited for 60+- to 67mm turbos
i'd use something in the 250's for a 3076 to fill up the powerband
cams need to be be matched to turbine/exhaust flow, as thats always your bottleneck....backpressure
sure you can shift your powerband to the right, but backpressure will be the one to have the final say in the matter
and nose the curve over generally, no matter how big the camshaft fitted
cheers
darren
Edited by jet_r31
  • Like 1
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996112
Looks like ill be keeping vct and going hks 256 in 264 ex with an exhaust cam gear. They look like a popular/good choice. Im after a fatter mid range and try to have a more aggressive overall power ban.
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996237
I know it does the exact same thing. But does it give as much of an improvement as lets say a vcam on a 26?
Hard to know the answer to that. Who would do a back to back with the OEM unit then a Vcam. Either would have much more twist down low than a static cam arrangement.
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996601
Same profiles as mine and at 800+HP :)
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996694
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
