Mugabetown - Whoretownin' At It's Worst.
Hope she's ok Ants :)
I had yesterday off sick. Got bored so rode to supercheap to get some things. Got a screw in my tire :( $200 later, new front on the bike.
Went home and got my AEM wideband talking to nistune. So I can log AFR's now :D
Thanks Mel and Mike.
Jannica is ok but I think she's lost the confidence to drive FTM
(Also lol Mike. If you're sick you should stay home sick otherwise you ain't that sick :P )
It's ok though, it will just take time.
I need to get another car now. Just not sure what?
Certainly not a Suzuki
Factory head studs are one use but allegedly ARP can be used multiple times.
Scottie already has ARP head studs.
He will need bigger ones to re-torque that head down properly before boosted up again.
Greggo, we made you a bookface: https://www.facebook.com/profile.php?id=100004790657312
Will PM you login details. You have lots of ppl wanting to be your friend ;)
#@Sick_R31
Ahahahahahahahaha :woot: Ricciardo :D
must be crazy to buy or even drive one to start with :ph34r:
really?
My definition of crazy would be to drive a 1500hp drag GTR as a daily in everyday traffic
Kinda would also be awesome!
http://www.imperialauto.com.au/index.php/online-showroom/nissan-cube-cubic-ex-detail
I'm taking this for a test drive this morning. Thinking about buying one for my wife.
or...
She might be even more terrified of potential accidents, but the price is right... especially if there's room for some forced induction! :P
https://www.facebook.com/ElioMotors
Or...
If she wants something that going to withstand a bus attack, I'm considering selling my SC300. ;)
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
