Stolen from the ACT boys section of the forums and thought it may work well on here too.
You lot should find this easy and understand, but if not:
Rules:
1. One word only
2. Must relate to the previous word
3. If you want to write a comment that is to be not included in the game, put it in parentheses ( )
4. Must be English.......
Eg:
Post 1. Apples
Post 2. Oranges
Post 3. Watermelons
Post 4. Boobies
Post 5. Jugs
Post 6. Cups
Post 7. Glasses
ect...
I will start with:
Murica
https://www.sau.com.au/forums/topic/431255-one-word-association-thread/
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
