Awesome(Pfft cosplaying doesn't make you a nerd Bunta)
Whatever helps you sleep at night. I went to that cos play thing at the rna. Every person in costume was in fact a nerd/geek/whatever. Most are in need of a good shower too.!
Fun
(I'll have you know bunta I cosplay and I shower regularly)
happy
(I haven't been lately but I have also been to Cosplay events previously and sorry to say but I am far from Nerdy, and also shower Same with my best friend back in Canberra!)
  • Like 1
