Hmm... I have almost got all the parts I need for my build. One thing that ive been searching for ages for is a head gasket. What is everyone's opinion on high performance gaskets vs standard OEM ones? Anyone running big power with standard ones?
I want to save some $$$ but if its crucial to buy a Cometic or something ill just do that instead.
  • Like 1
https://www.sau.com.au/forums/topic/431716-head-gaskets-vs-price/
Most of the time head gaskets let go because of detonation.. so by having that as the weakest link then it could potentially save the piston/rings which would be next in line if something went wrong.
Kind of like running street tyres vs slicks at the track. The street tyres are the fusible link, they will only take so much force before they just start baking. If you run slicks and then all of a sudden your shafts/diff/clutch need to be able to take a whole lot more force otherwise they go – if that makes sense.
With that said, I bought a Cometic 3 layer
Edited by R34GTFOUR
I am hoping for around 450 - 500rwhp. I sent an email to spool imports regarding the shipping price for a cometic gasket. Prices on Ebay seem a little expensive and plus I dont know if they are genuine or not.
Edited by Gameboy
I bought a cometic mls head gasket from Fabre Australia in Lakemba. I paid $300 for it but they were the only supplier in Australia to have a 86mm cylinder bore head gasket with 51thou thickness.
I just bought the same one from Spool Imports for $250 including shipping :)
  • Like 1
use the stocker. its fine for power even higher than that.
I used a rb26 oem one the first time, now im using a cometic metal multi layer. I have to say I liked the stocker better the difference in quench was noticable. it really depends on how much boost you plan to run and power figure.. for your goal.. it wont matter unless, as others have said, you want to save some $$$ if you need to pull the head off
Can you please explain what you mean by the "difference in the quench was noticeable"?
Providing you're using the same thickness gaskets, quench measurements should not be changed. You must be good if you can feel a quench difference!
I am making that sort of power on a stock head gasket
Edited by France
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
