Hey guys
I'm currently upgrading my front brakes to 4 pot wilwoods with 1.75" piston diametre and I don't think the standard master will cut it so I need an upgrade.
What do people normally upgrade to and what are the pro's and cons of the master?
Car is a 1989 GTS-4 Skyline with an RB20DET
https://www.sau.com.au/forums/topic/431886-r32-master-cylinder-upgrade/
I tried to google what master cylinder I had, but there's not a great deal of info on GTS-4s anywhere.
Will BMxx be stamped on the BMC somewhere I can check?
Although I could google the bore sizes of the master, it still leaves my initial question un-answered. Just because it's an available option, doesn't mean it's better than something else out there. I was more so after opinions, advice and feedback on what masters people have used and how they rate them.
Have you bought the calipers yet? If not buy the right caliper and you wont need to upgrade the BMC. BMC size isnt a performance thing...its a sizing thing. If you want better performing brakes for your Skyline you really only need to increase the heat dissipation....not the braking force. They have plenty std and are well balanced std. On an R32 perhaps they can do with a bit more bias. But you are getting that increasing the rotor size.
So what model caliper are you using . They can often be purchased with different sized pistons, get the right caliper and you are set
I have a BM50 Master.
I decided on the 1.75" (44.4mm) piston diametre, because my calipers standard are 40.4mm and I personally find them rubbish for track use. And using these calipers because they, being radial mount, allow me to run any size disc.
For the sake of the discussion what is rubbish about the std setup? Assuming you were running std caliper with 280mm rotors? What pad were you running? Did you find the stopping distance rubbish, feel rubbish, fade rubbish? All of the above?
Do you have ABS?
Sure. go to a bigger rotor, best value brake upgrade you can do. But increasing rotor size increase brake torque. If you massively increase piston diameter as well then you will be increasing the fron brakign torque by a boat load...only to have no real rear brakign torque....onlyu to have to put in a massive master cylinder or change the leverage ration of the pedal...either way you are going to need to put in adjustable brake bias to tone down the amount of braking force you have at the front which brings us back to the original point.....why increase the front brakign torque by sooo omuch?
I haven't bought any calipers or master yet, as the main reason for this post was to find out what options I have for a master if I went with my initial choice of caliper.
The brakes aren't "shit", but there is no way I'll get the times I want around the track on standard brakes. + If I'm going to use a bigger rotor, My caliper will need to be re-fit and it's easier to get a better radial mount that will withstand more punishment whilst doing so.
I currently have ABS, but pull the fuse for track use and I'm now at the stage of removal of the unit itself.
I'm currently up to about 3 pages of calculations in working out and I'm ready to pull my hair out haha. But so far, I think I'm heading in the right direction.
Will post up my findings once completed to hopefully give a better insight of the method behind my madness.
I found GTT brakes with a M/C stopper, braided brake lines, Motul RBF600 brake fluid and quality pads perfectly adequate on the track for my 18ookg Stagea so I am sure they would do for your lighter GTS-4. I only got the D2s when I got the heavier RB30 in the front together with much greater kw and speeds!
Well if you think your sizinf is correct it will be interesting to see how it all goes then. I think no matter what caliper you do if you are looking at crunching out good times and your 4dr is AWD I think 325mm rotors wont last much longrer than std, irrespective of the caliper and ducting/pads etc you use
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
