Morning fellas,
As the titles states I seem to be having a major issue with the A/C in my ECR33. It seems to be leaking refrigerant in the passenger footwell and as its evaporating (through the vents for the demister), fogging up on the windscreen as it goes. There's no overheating problems with the engine at all, as temps are normal throughout.
2EF7EBC5-118A-4446-B529-A25DFC817703-212
C9CEFC9A-18EA-470C-AB3B-0EA54DE6B72A-212
^Where the leak in the cabin is occurring.
Now basically this needs to be fixed ASAP, but will the leak/evaporation continue to occur if the car is driven without the cooling system used at all, and has anyone ever had a similar issue at all?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/
is there any refrigerant left?
If this is the case, disable the A/C immediatly or you may destroy the compressor if you turn it on.
Are you sure that its the refrigerant causing the window to fog up? Or just because there is no A/C action to demist the window?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020810
ac systems have a pressure sensor, so if there is no gas in the system it won't engage the compressor and damage it. Are you sure it's refrigerant, it might just be condensation due to the drain being blocked. The refrigerant is a gas that dissipates, the lube oil is what would drip out, so is that liquid oily or watery?
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020875
That could definitely be the heater core. I had the same in one of my cars. Wet passenger footwell and foggy windows.
Get a white paper towel and press it onto the wet area. Check its colour. Smell it and feel it. You'll know if its coolant if it is. It could be your ac drain but I doubt you've used your ac enough for that.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7020969
Thanks for the replies fellas. Okay I could be wrong, but the window definitely isn't just fogging up because of the A/C demister not working, the fluid leaking is 100% causing the fog up. Also ill double check coolant levels when I get home, but the smell coming into te cabin has a very distinct collant sorta smell too it.
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7021256
Coolant smells really strange, you just know its coolant. It also feels oily to touch. There are two methods to fix, the hard method is to replace the heater core. The easy method is to bypass heater core then use an air compressor into the core to shoot the rest of the water out.
Also to clean up the coolant do what I do, go to the local 24hr carwash and throw two bucks into the vacuum machine.
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7021577
There is a "how to" in this site on changing the heater core without pulling the dash out (via the glovebox etc). Due to try it myself shortly.
Cheers mate ill be sure to check it out, that's the main thing that had been putting me off replacing the core itself. The sheer effort of the dash removal lol.
Edited by gtsttrk
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7027454
Here ya go:
http://www.skylinesaustralia.com/forums/topic/280174-removal-replacement-of-heater-core-skyline-the-right-way-without-removing-the-dash-at-all/
https://www.sau.com.au/forums/topic/431888-r33-ac-problem/#findComment-7027701
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
