Hey guys, first of all yes I have searched -but couldn't find anything more recent than 2007.
Hey guys, was planning to hit the drags today but hit something of a snag with my helmet being more than 10 years old (it's a hand me down from my old man). I want to go out and buy a new one in the next couple of days to hopefully get down on Wednesday.
So who is using what and where did you get it from? I can find heaps of online suppliers but not many physical stores.
Would a full face bike helmet be OK provided it conforms to appropriate standards? Or should I really be looking at a "motorsport" helmet? Bike helmets seem to start around $90 up to $400 for something top of the line (carbon fibre, ventilation etc etc) whereas motorsport helmets seem to start around $400?
And any thoughts on the helmets below?
http://www.autosport.com.au/itemdetailspage/15361
http://raceline-racewear.com.au/pyro...ce-helmet.html
I had a look at Sparco and Revolution racegear websites but couldn't find much in the sub $700 range.
https://www.sau.com.au/forums/topic/432495-helmets/
If it's a quick purchase, pop down to your local bike shop(s) and try them on for fit. Note some ebay imports don't come with aussie standards stickers though apparently you can purchase those stickers online too?
Personally run plain colour full face with visor removed (no ventilation issues in closed cockpit) with sunnies. Iirc $300-500.
This is old and you can ignore their recommendation but it explains the testing process and international standards that get pushed.
Google "blowing the lid off"
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7043362
Thanks for the feedback, there's a warehouse about an hour drive from me I can probably head to and try some on
This is a bit of a worry! If it's protecting my head I think I'd rather pay a little more for one that comes with a sticker... even if it is the same product...
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7043369
can't go wrong with an rjays, <$150 and meets all the aus safety requirements.
like others have suggested, it's recommended to head in store and try them on to get the perfect fit.
http://www.mcas.com.au/motorcycle-helmets-road/rjays
http://www.mcas.com.au/our-stores
Edited by pphhhfffttt
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7044100
So I bit the bullet and went with the Velo from my original post. $399 with overnight delivery seemed a fair price (after doing some digging) for a basic motorsport type helmet, and complies with SNELL2010 so I'll get another 6-7 years out of it.
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7045426
Good choice. Let us know what you think. The only place I had really looked was Revolution Racegear and their line of Bell helmets. Those Velo helmets are a fair bit cheaper than what I was expecting to pay.
http://www.revolutionracegear.com.au/index.php?PCID=15558&PSO=245&PSID=522650000-&PSV=Primary&CDO=
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7046099
Any reason why the Velo helmets are so much cheaper?
Dunno -I've seen the full face velos advertised up to about $499, but that first site I linked to is the Australian distributor so maybe that's why they're a little cheaper via their online store?
It's also something of a "no frills" helmet -leaves out a lot of features that I just don't need for the type of use it'll be getting.
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7047820
only one thing to keep in mind; if you might be getting serious in the future and want a HANS device, you might want to consider the HANS posts when you buy the helmet....they can be expensive or impossible to add later.
personally I use a cheapy motorcycle helmet, whatever fits comfortably. Also get a decent helmet bag and use it, scruitineers will knock back helmets with surface damage, even if it was only a scratch while rolling around in the boot.
BTW that article is very interesting and worth the read....it's not fully relevant to race car use but had interesting conclusions
  • Like 1
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7064892
You use a motorcycle helmet for door to door racing?
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7065179
absolutely. and that helmet report explains why
here is the CAMS rules, section 3.1 http://docs.cams.com.au/Manual/GeneralRequirements/GQ05_Schedule_D.pdf
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7068229
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
