Hey guys, first of all yes I have searched -but couldn't find anything more recent than 2007.
Hey guys, was planning to hit the drags today but hit something of a snag with my helmet being more than 10 years old (it's a hand me down from my old man). I want to go out and buy a new one in the next couple of days to hopefully get down on Wednesday.
So who is using what and where did you get it from? I can find heaps of online suppliers but not many physical stores.
Would a full face bike helmet be OK provided it conforms to appropriate standards? Or should I really be looking at a "motorsport" helmet? Bike helmets seem to start around $90 up to $400 for something top of the line (carbon fibre, ventilation etc etc) whereas motorsport helmets seem to start around $400?
And any thoughts on the helmets below?
http://www.autosport.com.au/itemdetailspage/15361
http://raceline-racewear.com.au/pyro...ce-helmet.html
I had a look at Sparco and Revolution racegear websites but couldn't find much in the sub $700 range.
https://www.sau.com.au/forums/topic/432495-helmets/
If it's a quick purchase, pop down to your local bike shop(s) and try them on for fit. Note some ebay imports don't come with aussie standards stickers though apparently you can purchase those stickers online too?
Personally run plain colour full face with visor removed (no ventilation issues in closed cockpit) with sunnies. Iirc $300-500.
This is old and you can ignore their recommendation but it explains the testing process and international standards that get pushed.
Google "blowing the lid off"
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7043362
Thanks for the feedback, there's a warehouse about an hour drive from me I can probably head to and try some on
This is a bit of a worry! If it's protecting my head I think I'd rather pay a little more for one that comes with a sticker... even if it is the same product...
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7043369
can't go wrong with an rjays, <$150 and meets all the aus safety requirements.
like others have suggested, it's recommended to head in store and try them on to get the perfect fit.
http://www.mcas.com.au/motorcycle-helmets-road/rjays
http://www.mcas.com.au/our-stores
Edited by pphhhfffttt
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7044100
So I bit the bullet and went with the Velo from my original post. $399 with overnight delivery seemed a fair price (after doing some digging) for a basic motorsport type helmet, and complies with SNELL2010 so I'll get another 6-7 years out of it.
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7045426
Good choice. Let us know what you think. The only place I had really looked was Revolution Racegear and their line of Bell helmets. Those Velo helmets are a fair bit cheaper than what I was expecting to pay.
http://www.revolutionracegear.com.au/index.php?PCID=15558&PSO=245&PSID=522650000-&PSV=Primary&CDO=
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7046099
Any reason why the Velo helmets are so much cheaper?
Dunno -I've seen the full face velos advertised up to about $499, but that first site I linked to is the Australian distributor so maybe that's why they're a little cheaper via their online store?
It's also something of a "no frills" helmet -leaves out a lot of features that I just don't need for the type of use it'll be getting.
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7047820
only one thing to keep in mind; if you might be getting serious in the future and want a HANS device, you might want to consider the HANS posts when you buy the helmet....they can be expensive or impossible to add later.
personally I use a cheapy motorcycle helmet, whatever fits comfortably. Also get a decent helmet bag and use it, scruitineers will knock back helmets with surface damage, even if it was only a scratch while rolling around in the boot.
BTW that article is very interesting and worth the read....it's not fully relevant to race car use but had interesting conclusions
  • Like 1
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7064892
You use a motorcycle helmet for door to door racing?
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7065179
absolutely. and that helmet report explains why
here is the CAMS rules, section 3.1 http://docs.cams.com.au/Manual/GeneralRequirements/GQ05_Schedule_D.pdf
https://www.sau.com.au/forums/topic/432495-helmets/#findComment-7068229
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
