joined the crew. Gamertag: elementle
Am happy to stay as 'muscle', probably won't be the most involved player. Don't have a mic or anything, but happy to rack up crew points shooting shit up solo or with my other friends [if that's how the crew system works(?)]
Thats it, I'm moving to this Austrlia Place. Sounds good
Been checking all day to see if online was up. There was a few mixed reports about when it would go live, but 9pm AEST seems to be the best bet right now
Finally linked the game to my Rockstar community account today expecting I might be able to do something, but couldnt do anything at all lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
