No headset for me. Funnier to laugh at people without them hearing your response.
2 guys tried to pull a swift one on me while i was mucking around in the big drain thing that runs out to the ocean (mental blank, should remember what its called.....)
anyway. Hid behind the car and mowed one of them down 3 times in a row :)
i use headset occasionally... have button nearby to switch it off. so you can listen to music/sneeze/eat without annoying people. dat PC-esque consideration.
All my tattoos glitched out but they returned when I visited a tattoo parlour.
Got arrested last night (in game lol) and had to steal my car back from the impound or else it would get crushed. Pretty clever mini-game! tried to stealth it, but the game is almost completely perimeter based.
eg. enter area, everyone turns enemy. or steal car and drive it out of driveway, trigger po-lice. stealth isnt adding up to much... neither is my $12,000 silencer considering sometimes you get a wanted level for doing f**k all.
shit it'd be nice to do a crew/friends only session - no bullshit with dickheads
i still don't get why you can't say "okay stick with these people" between missions and freeroam and everything - go as a fkn group
try setting up an 'invite-only' session.
Has anyone done 'Titan of a Job'?
You get it from Lester at lvl 25, he asks you to get a helicopter, fly into the airport and steal a Titan transporter plane from Merryweather.
Tried it with a friend, spent 20 minutes driving around the map looking for a helicopter. No freaking idea what to do.
i managed it at level 10. managed to get on with a guy who was level 30. he died. took me ages of sneaking around capping the merryweather blokes. but i managed it. however titan was f**ked. flaps and 2 engines damaged plus the fact that my character cannot fly, made an extremely interesting flight.
got about 10k i think?
my headset is usually on mute got a g35 so game sound doesnt play though it only voice which sucks sometimes..
u can usually get helicopters from the hospital roof or theres some down by the wharf where they do the city tours
Don't think it has been mentioned here, but Rockstar are going to give everyone $500,000 (in game money of course :P ) due to the problems at the start of the online launch
Trying to remember what it said (popped up as one of the online tips while waiting for online to load free mode) but I think it was anyone who has played since the launch of online up until the money is made available.
Sooooo many car mods and garages :P
yeah i mentioned it a while back.
You get 250k sometime this week at the next update. Then another 250k towards the end of the month.
Only prerequisite is that you have played (or will play) at any point in time throughout the month of October.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
