  • Replies 47
Nah, that's the chick from Today Tonight...
They did a story on a Police raid, how they video taped these idiot burnout hoons who met every week in some residential area and did burnouts for hours on end... 100-ish spectators, and 5 or 6 main culprits doing the burnouts. The Police videotaped them for a month or so to get evidence on tape, and then planned a huge raid where they blocked off all the roads and trapped everyone inside and went searching for the main culprits. Her boyfriend was one of the main morons and from memory, he was this skinny, "ful sik" type ;)
He's such a hero, that he quickly shoved his fat-ass gf in the drivers seat to make her take the heat, but Police > stupid habibs and they dragged him out of the passenger seat and handcuffed him on the spot. Then the camera panned to his gf in the drivers seat and that's what she looked like.
:( :( :D:)
:( :( :D:)
u serious???
if so i think the habib would b more embaressed bout having her in the car, and being on tv
Merli, you failed to tell us how big the exhaust tip(s) was - if it's big enough to put a body-builder's leg in, then that's gotta be about 130kW (per exhaust tip, of course). And if the outlet is at least twice the size of the piping before the rear muffler (if it has one), then the figure doubles!
Someone's already pointed out the lack of info on type/number of stickers attached to the car (airbrushing adds 35% over stickers), but the Chromies should be worth about 80kW per corner.
A GT-style rear wing would bump up the figure somewhat, considering the new technology and subsequent improvements gained in this area since the release of the Veilside-type wing.
Also, power would be lost due to the lack of fitment of a DVD player - fancy going to all that effort and not carrying out this final (and simple) mod! Oh, the horror... :)
Nick T.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
