The point of it is that Nissan Japan sold the GTR within the existing "Gentlemen's Agreement" that said no manufacturer would release a car with more than 205kW (or 206, or 207 or 208, depending on who you listen to). The restrictor was put in the boost control system to set the boost to a level that would stay pretty much within the gentlemen's agreement, but was trivial to remove and make GTRs close to unbeatable on the street (which was one of their highly desirable aims, of course).
The ECU will happily run the engine with that much boost, but it wil be richer and more retarded than if it was tuned properly. Rich and Retarded is a little safer on the engine. Well, the richer part certainly is. Retarded can be less safe sometimes. But I digress. Yes, for 15 years after the release of the R32 GTR people would simply pull that restrictor out and just drive it round. No problem.
So I think I took the right line off and looked in the hose and can't see anything, how far down will it be? I'll upload a pic maybe to make sure I have the right hose. Maybe previous owner already removed it
The boost gauge just goes to the top 7+
On a side note/question I started my car this arvo after being parked for 1 hour maybe and it just stalled then I started it again and the idle was
Real rough like it was going to stall but I kept the revs up a bit, this has also happened once before any ideas what it may be?
Once driving its fine both times have been on startup
Hmm could be a loose earth or even dirty AFM
Is there any particular mods like a vent to atmo BOV
The only way a bov would effect the car on idle would be a seriously rooted spring, and the problem would a hell of a lot more noticeable during boost, in for form of no boost.
Did the splutter only happen after stalling? Or does it just randomly happen on startup?
Yer it is randomly on startup, it stalled then when I started it again it spluttered a bit and started dropping revs but I gave some aceleration to bring the revs up for a couple of seconds then it was ok held fine on idle
factory bovs are slightly open at idle due to the manifold vacuum acting on them,(and don't leak under boost) so I would assume some after market bovs could be the same.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
