So I've done some more researching lol. It appears I need a bigger pump and not bosh cos they only have 500hr life on e85 and somewhere between 1000 and 2000cc injectors and then a tank of nectar. I guess the hunt for parts begins
I've read everything and hence my surprise at some of the recommendations. Should have been clearer that I was whinging rather than asking. Seen enough threads to know what miserly GTR owners have shown works.
I was expecting to install the turbos and run stock piping and intercooler. But hard to TELL the mechanic what is best when he considers it his job to know. So new mechanic may be the way to go.
So thanks everyone for the usual "assistance".
does the fuel rail need to be replaced? I read on one thread it does then in another it doesn't. I wouldn't think you would have to. And what do u guys recommend minimum cc injectors. There are some 800cc for sale that say e85 compatible.
Stock fuel rail is fine.
Injector sizing is dependent on what you want from the car power wise. Usually 1000cc Xspurts are what I recommend, unless you want more than 400kw in the future on e85.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
