Love my RB30/26, would never go back to having the 2.6
Makes heaps more torque at a much lower rev range, and it doesn't need to be revved to death to make power.
.....car should have come with it already in here.....
To do the complete oil fix properly it's a head off job anyway. One of the best things you can do is improve the head oil returns to the sump. I reckon I took about 10mm out of my head around each of the 2 main holes, they're so much smaller than the galleries in the block.. Nissan really did do a shit job at the factory of finishing off the head.
Yeh I realise this... What I'm thinking I mite do is: I'm on a good thing with a very reasonably priced fully built 30/26. I'll buy this engine and keep my 26 and do the oil mods and have it as a spare... If the 30/26 lasts say 10,000km I'll deem the build reliable and then I mite think of selling the 26?
Yeh I realise that. My thinking is: the 26 is stock so you know it is put together perfectly at Nissan with the added piece of mind I have already tried and tested it. The 30 has been built by a shop and all it takes is one small thing to go wrong and bang...
I agree. My car has been off the road for 12 months now building my 30. Leave the 26 in until the 30 is ready to bang in. I did the same as what you're proposing- buying a built 30 assuming I could whack it straight in and away I go. Mine was a lump of shit and I had to start completely from scratch. Don't waste your time unless you're 100% on the engine you're buying. If you don't have a young family and other committments then you'll bowl it over a lot quicker than what I will!
I have a 30 block and a 26 head for sale if your interested mate.
I would have built it but other things come up and my 26 doesnt show any signs of letting go anytime soon.
PM if your interested.
Hmmmm ok. Anyone here that has had both and can explain why it will be that much better apart from the moderate power gain?
have had both.
for street, go the 30, alot nicer to drive due to better low end.
for track, keep the 26 until it pops, the replace with a built 26.
alot easier to swap in/out if anything happens as everything just bolts up.
where abouts are you located?
response and power out of corners come down to turbo selection.
see if you can go for a ride in someones car that has the conversion.
was going to offer, but its a little far for you to travel.
Honestly, if it's 90% track you don't need anymore power. As previously said put some forgies and rods, balance it up, get the oil control sorted and your done. Spend the rest on chassis and suspension setup. 370 is more than enough. Also a revving 26 sounds much nicer than a stroker or a 26/30. Whoops did I say that....sorry.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
