Fair nuff, though for future reference or anyone else's benefit, the turbo and exhaust manifold can all be removed with simple hand tools. You'll need a few sizes of socket wrenches for the tight spots, and a selection of spanners. Other than that you may need to get a thread repair guy out, as I did when a stud broke (or probably was already broken). Good time to replace all the studs and gaskets.
As a matter of fact I think I only had to get underneath the car to get at 3 bolts. Hear that M35 guys? Its soooooo hard on an RB......
The biggest thing that scared me away from the repair was how to do the welch plug(s) themselves as it's not something I've ever done and no-one I know has done.
I looked over what it was to get the manifold off and it didn't seem like it would have been a major issue.
Just sold a car too so I'm cashed up now to get the Stag done quickly and professionally as it is my daily driver.
Welchies are not that bad to do. The key to successful repairs on anything is prep work AND cleanliness! Using a sealant like Permatex aviation No.3 is also ideal, especially on an older block.
  • 3 weeks later...
So here's an update on my stagea.
Mechanics have done a bunch of work
- replaced 4 welch plugs on that side of the block
- replace crank seals
- replace cam seals
- replace timing belt
- replace thermostat
- replace water pump
- replaced inner cv boots
- replaced turbo (stock v45 i supplied as the old one had a terrible whine)
- fit supplied aftermarket oil filter re-location kit (inner feed tube thing was too big to fit in the block apparently :()
- flush water
- replace oil & filter
Picker her up last friday arvo and got it home late that night. Did some driving around on Saturday morning all good.
When for a trip down to the gold coast and had it overheat quite bad once and not so bad three other times afterwards... only on the highway @ ~110km/h under load and not in peak hour traffic.
Saw the mechanics again this morning and they've basically confirmed my fears the original factory radiator is either blocked/getting blocked. They flushed it once after doing the welch plugs and when I got them to have a quick look today the water under the cap is starting get very brown again.
Couldn't see an obvious leak/crack or excess pressure build-up so we're only assuming this is the problem so far.
Can anyone recommend some replacement radiators that I should look at?
The mechanic suggested not anything much more than 45mm thick as this could restrict the airflow too much.
I'm thinking that I can get one off the net an replace it my self and flush the system a couple of times.
Any thoughts are appreciated, if you've read this far :P
Most of the buckchoy alloy 42mm ones will do an acceptable job.
SAU NSW members get a discount on Fenix radiators and the one I installed in the S2 Stagea works perfectly and fitted with minor shroud trimming. The radiator in the GTS-t fitted without any trimming.
  • Like 1
Edit: i'm in QLD and not an SAU paid member
Had a quick ebay browse last night and i can see 'mishimoto', 'koyo' and some other ones that allegedly fit the WGNC34.
Thinking I might just buy one of these and fit it myself.
Another interesting thing to note; if I brake really suddenly the engine stalls... mechanic mentioned it might be the AFM recognises the lack of airflow and the ECU thinks the ignition has been switched off...
Edited by wookster
One thing that you need to remember is that the oil cooler for the transmission also runs through the radiator, and most alloy radiators don't have this built in. It is simple to put an external cooler for the trans but sucks when you forget and have to order a taxi to get you to the spare parts shop!!!!!!
Edit: i'm in QLD and not an SAU paid memberHad a quick ebay browse last night and i can see 'mishimoto', 'koyo' and some other ones that allegedly fit the WGNC34. Thinking I might just buy one of these and fit it myself.Another interesting thing to note; if I brake really suddenly the engine stalls... mechanic mentioned it might be the AFM recognises the lack of airflow and the ECU thinks the ignition has been switched off...
time for a new mechanic :) The ecu doesn't have to wonder if the ignition is on or not, is connected to the ignition.
Hahahah oh dear that story sounds terrible.
Sorry mate, it's a manual (factory RS-FOUR-S) so I believe there is no tranny cooling you mention.
Hmmmm... so is it possible that if enough air isn't flowing could this ruin mixture and maybe flood the engine?
Braking hard and it stalling on me makes me very confused...
Edit: i'm in QLD and not an SAU paid member Had a quick ebay browse last night and i can see 'mishimoto', 'koyo' and some other ones that allegedly fit the WGNC34. Thinking I might just buy one of these and fit it myself. Another interesting thing to note; if I brake really suddenly the engine stalls... mechanic mentioned it might be the AFM recognises the lack of airflow and the ECU thinks the ignition has been switched off...
I realise you are not a NSW member but the alloy radiators are more or less the same design so they will fit regardless of where you buy it from.
Is your brake booster leaking?
+1
We're going to need alittle more info.....
Has the brake booster hose been off? There is a one way valve in the hose.
What condition is the air filter in?
What is the idle like?
Does it run abit rich?
+1
Not by me, the mechanic might have...
Pretty good. Previous owner had a oilable one in the factory airbox which I keep reasonably clean, though I havent cleaned and re-oiled in about 6 months, maybe ~6000kms.
Idle seems fine, ~650 rpm when up to running temp
The AFR guage (aftermarket - previous owner) on the dash indicates not lean or rich at cruising speeds. Not sure on a good way to guage richness off the top of my head?
Thanks, I've heard some people like em. PWR was recommended as the top notch ones from the mechanic (~$900!)
Koyo is the OEM; very high quality product. Priced accordingly.
More than one person on this forum would disagree with the opinion of your mechanic.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
