Just got back from my first visit to Kwinana Mororplex having pulled out an 11.9 second pass in my R33 GTR which has:
Standard Internals/turbo/fuel system
294KW@RW's
Terminal speed of 116.88mph, 0-60 ft 1.827 AND reaction time of 0.53 so this time can be improved with a bit of practice.
The R34 GTR is having the twin plater installed this week so next weekend I might have to get it down to the strip and see how it goes.
Jeremy
p.s. if anyone knows hoe to post attachments I can email them the timeslip
https://www.sau.com.au/forums/topic/43406-11-second-standard-r33-gtr/
  • Replies 59
294KW@RW's
Jeremy
thats a bloody good time on standard turbo's! well done!!
im saving up at the moment for an exhaust and PFC for my GTR, cant wait!!
intercooler
pod filters
apexi PFC
Full exasut incl dumps
onehelluva tuner
Hey Jez that's a great time. Who installed the dumps for you? I have a set we want to put on my car, but we're told it's a bitch see thread
http://www.skylinesaustralia.com/forums/sh...ead.php?t=43354
All those mods are on the 34 not the 33 that I did the 11.9 in.
A guy in perth did my dumps for $300 and did an awesome job, you wont get that price in melbourne though
Is 1.2bar within the approximate *safe* boost limit of the stock ceramic R33 GT-R turbos? If it is, then that's one hell of a 'bang for bucks' package! If not, then it might eventually go bang and cost lots of bucks :P
It wouldn't be safe to run that kind of boost constantly - ie on track or driving hard through windy roads...
not sure how safe it is for short bursts.... most people seem to run 1bar, but even that isn't safe to run on a track
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
