Ok I have been asking for advice on my build and as we speak. I have got the following parts.
1. Set of rods and pistons. Manley rods with 625 bolts, cp pistons with 9310 pins.
2. Tomie over size oil pump
3. ACL race bearings.
4. ARP head studs and main studs.
5. Cometic 1.3mm thick head gasket
6. 1.1 head oil restrictor
7. Supertech intake and exhaust valve seals.
8. Head oil drain kit.
9. New OEM cam and rear oil seals.
Im waiting on a new oem crank with the long oil pump drive and a new cylinder head. With some valve and spring. Then I can start the build.
I have a few queation regarding a set of new hks cams and for my goal of 600 hp should I use them. I plan on drag racing the car more than driving ir on the streets. I have a stock r33 gtr for street use.
The cams specs are stock lift but 272 duration. I dont have much experience with cames as I always go stock cams on my builds. The biggest difference going from a gtst to a gtr is that I just launch the hell out the gtr rpms are in the 8000 area all the time. Will these cams help me or slow me down for my 600hp goal.
My next problem is. I know of the rb oil issues and have never had real big oil pump failures in the past. Thats on rb25 builds. Now with this new oil pump. (Tomie) should I go with the ovwrsize oil pan or is it a waist of money?? I see that Raw Brakerage has a service to inlarge my pan for 1100 usd. They also put the head return on the pan but on the intake side. Is this a good idea.
Edited by MJTru
https://www.sau.com.au/forums/topic/434325-what-cams-to-go-with-on-rb26-build/
I am definatly no expert on this topic but I would have thought your valve train would be the most limiting factor on deciding what cams you go, not power. I personally would go high lift high duration because an increase throughout the entire powerband would be advantageous. But I assume you are worried about valve float because of the high rpm launches?
I didnt choose these cams they came with the motor from japan. Valve float did cross my mind. The turbo is a PT 6262.
I personally was planning on selling them and going for stock ones, cams that is. I got the set of valve springs for stock lift. I was told that I can increase the lift a little. But will be fine use the hks cams. Yes I was told by the old owner of the car that the cams are stock lift and 272 duration. These numbers didnt come from me but the person who got them. In my head thats risky.
Im already turned off. So I guess ill just get a set of stock cams.
I can remember reading an old thread where people made better power using there oem cams over several brands out there. It had mentioned that if the whole valve train wasnt looked at it may be better to go back to the stock cams.
Any ideas on the oil pan.
Read the oil control thread or if you don't want to read all of it just the first few and last 10 pages say.
The Tomei pump should not fail but it can empty your sump. The restrictor will help. The head "drain" will not but if you are going to fit it the exhaust side is preferred. The enlarged sump is also good insurance against engine failure...although the price looks high - are there alternatives? I would recommend drilling and tapping two holes as high as possible in the inlet side which you can plug if you are not going to run breathers. That way if you do decide you need breathers later you won't have to pull the engine and remove the sump.
I have done a lot of reading in those threads but thats about a year ago. I decided to go with the head drain as insurance. I understand by putting the restictor in the head will reduce the amount of oil in the head and really make the head drain redundant.
I was looking over the oil pumps manual and it does say that I need a enlarged oil pan.
Does anyone know of another option thats cheaper that 1100 usd offered by raw brokerage. It looks to be a very clean unit with extended oil pick up and oil pan baffles.
As for the cam. Yes sir. Its intended for drag racing. I will attach the supertech part number for the valve springs.
With such duration I will need stiffer springs to avoid floating valve effect right. This is the reason I want to post the part number I got.
I have heard that this duration will kill low end power but make up for it on the top end.
Can you please explain just a little about the subject. Like pros and cons.
Edited by MJTru
I was pretty sure tomei/hks/nismo did sump baffles, but nothing is going to be as reliable as an extended sump, especially at the high rpm for drag racing. I would do it just for the reliability of the engine.
I think by low end they mean 1-3k. Which for a drag car you will use 0% of the time. I believe the reason the low end suffers is because before the turbo begins to spool you are essentially trying to suck air in, and with a huge duration, it becomes null and void, but as soon as the boost kicks and it starts to push all the air in, the duration and lift begins to shine because you are able to force so much more air in, in comparison.
I am not sure about the figures, but I believe stock is 9.15 lift, 264 duration?, hks step2 is 10.15, 272 duration? That is hell of a lot more air. I was reading the rb26dett tuning page and it said someone got a 60hp increase just from cams and adjustable cam gears.
Obviously if money wasn't an issue, vct would make up for the loss of power low end...?
Supertech SPRK-M1007S/RB
Specs:
Outer Spring O.D.: 28.10mm
Outer Spring I.D.: 20.00mm
Seat: 70 @ 40.7 (lbs@mm)
Open (lift): 188 @ 11 (lbs@mm)
Max net lift: 16.00mm
Coil bind: 24.70mm
Rate: 10.50 lbs/mm
These are popular here but freight might kill it for you:
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/engines/auction-654508309.htm
Piggaz is right those are the stock cam specs.
But can anyone answer my question as to the supertch sping specs will work or not. Eather hks steps in sure of the duration, but ill mesure the lift today and tell you.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
