Suspension, Brakes, Wheels And Tyres Upgrade
Hey guys,
Planning to do a suspension, brakes, wheels and tyres upgrade on my R33 GTR in the next few months. Here is what I'm thinking of so far:
Volk TE37SL 18 x 11
295 Semi-Slicks on all four wheels (still deciding on whether to go Kumho or Federal semi's).
HKS Hipermax 4 Suspension
Adjustable upper and lower control arms, roll center adjuster, swaybars, link pin and HICAS lock bar.
Project Mu 6 pot front and 4 pot rear brakes
Really looking to build a car that's quick around a track (but it will still be driven on the street). Pretty open budget, would prefer to go better brands / quality for a bit extra money. Any thoughts or suggestions?
Thanks.
Open budget...Hmmm
Wheels - Custom BBS/OZ forged magnesium wheels.
Suspension - Sachs, Aragosta, Bilstein Ennepetal, Ohlins (Euro), KW, custom MCA golds
Tyres - Michelin Pilot Super Sport, Pirelli P Zero
Your budget is way way above what I would want to spend but certainly not an open budget if those are the sort of brands/upgrades you're looking at :P
In the meantime, I'll keep dreaming :thumbsup:
Federal 595 RSR's are used as a street/light track tyre by many members, they aren't a true semi slick but they can also be used as a road tyre that wont wear out insanely fast.
As for suspension, don't go silly hard spring rates, our roads and race tracks in QLD are far to rough for hard suspension. Just go bigger sway bars to control body roll.
So far this is what is confirmed on the build:
Volk TE37SL 11" Rims
Whiteline 22mm Front Swaybar Adjustable
Whiteline 24mm Rear Swaybar Adjustable
IKEYA FORMULA Front Upper Arms
IKEYA FORMULA Front Roll Centre Adjustor Lower Kit
IKEYA FORMULA Rear Upper Arms
IKEYA FORMULA Rear Traction Adjustor Rod
CUSCO Rear Drag Rod
Here is what will most likely be going with the build (just looking into pricing at the moment):
Project Mu Billet 6 Piston Front Caliper Kit with 380mm Rotor Disc
Project Mu Billet 4 Piston Rear Caliper Kit with 345mm Rotor Disc
Still looking around at tyres and suspension.
Tyres, the Acilles 123Rs are hard to beat value for money or if you want full semis then the 050s or Z221 Hankooks
Suspension, pm Piggaz. He has just gone through all of the suspension dynamics for his R33 GTR and got a custom set of Bilstiens built
Haha t5iv, that cracked me up.
Nismo LM GT4 rims are currently what I have on the car but the rims aren't wide enough for the tyres I'm looking at. My mechanic recommended the Volk's and they are pretty much the exact look I'm after.
I am quite funny. Do you have a Gts-t and a GT-R?
Sounds like this thing is going to handle quite well. When are you planning on having all this done? Will she still be coming to the Charity Cruise?
Nah I had a Gts-t but it broke down constantly so I got rid of it. Only recently bought the GTR (had it for about 6 months now). Most of the parts are on order but some of the stuff won't be here until the end of January (so end of Jan / early Feb is when all this will be going on). Havn't even looked at the Charity Cruise to be honest. When is it?
8 December mate. Would be great to see you out there!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
