Sold the car and I've got this stuff I need to move on so its going on here. The OEM parts are from 1993 R32 GTR with 120,000km
1. S15 Silvia/200SX pair Rear RDA slotted rotors with metal backing plates (thickness unsure) FREE
2. 4x S15 Silvia/200SX Rear brake calipers 3 of them are leaking and have been disassembled 1 of them still operating fine. Have 3 used Nissan brake pads to go with them and also have handbrake cables attached $20 the whole lot. Picture is of the 1 remaining caliper that operates fine.
3. Endless MX72 rear brake pads for all Silvias S13/S14/S15 brand new in box $250
4. R32 GTR HICAS pump. HICAS was working fine when it was removed form the car. $10
5. R32 GTR RB26DETT OEM Fuel injectors x6 were leaking fuel due to perished O-rings. New O-rings and a professional clean and test and should be good to go. $100
6. R32 GTR OEM Fuel pump. Little bit of corrosion on the surface. Worked fine when removed from car. $10
7. R32 GTR RB26DETT OEM Ceramic exhaust wheel pair of turbochargers . Worked fine when removed from car. No shaft play and very smooth. $100
8. 350mm Deep dish suede steering wheels x2. Came with my HKB boss kit that I purchased. One steering wheel has horn button other one doesn't have horn button. These steering wheels will bolt up to the same pattern as Nardi wheels. I bought a Nardi wheel to use with the boss kit so no use for these wheels. $10 if you want the horn button. $5 without horn button.
9. Old school Tomei remapped ECU for R32 GTR RB26DETT. Suitable for cars running standard injectors and AFMs. Worked fine when removed from car. Everything runs just like OEM except engine revs out smoother. Cheap and tidy way to remove 180km/h speed cut from your R32 GTR $80
10. HKS Hipermax IV GT Coilovers. Bought brand new from Japan via Jesse Streeter earlier this year only used for about 4 months and 4000km before car got sold. Complete set including cable ties, C-spanners, certificates and instructions. 7kg Front & Rear spring rates. Excellent balance of handling and ride comfort for road use. Guaranteed working 100% genuine Japanese quality. $1200
11. Professionally welded up R32 GTR Rear HICAS steering rack. Cheap and effective way to lock out HICAS without resorting to buying a dodgy HICAS lock bar. $50
12. Nismo R32 GTR steering rack bush/mount kit. Brand new in bag never installed $50
13. R32 GTR RB26DETT OEM air box including air filter. $150
14. Brand new Genuine Nissan Oil filter 15208-H890C suits R32 GTR RB26DETT and anything else that accepts the same filter. $15
15. Ryco Z387 fuel filter to suit R32 GTR RB26DETT. Used for about 1500kms. FREE
16. R32 GTR RB26DETT OEM Radiator. No leaks. Doesn't come with radiator cap. $70
17. Nismo high pressure radiator cap. Bought brand new and used for about 4 months. $25
18. Apexi RSM Blue version. Unwanted extra given with other purchase. Was assured that it works from previous owner. $50
19. Genuine made in Germany BBS RS RS261. 17x9 +20 offset with centre bores made to 66.1mm to suit Nissan hubs so no hub rings required. Includes centre caps. Contisport3 tyres 225/45/17. 2 completely bald and 2 with minimal tread left. Light gutter rash on some of the wheels. Not sure what these are worth since they are quite rare. $1800 or reasonable offer
20. Intima SR low dust rear brake pads to suit Silvias S13/14/15. Used for about 3 months estimate 85% meat left. $50
Contact via PM.
Pickup in Sydney Metro area.
Free items are pickup only.
May post at buyer's expense.
Advertise them GT-R Injectors on calaisturbo.com.au, they'll sell for $300 easy. Cheap upgrade for all the boys going Nistune and running 220rwkw.
  • Like 1
NISMO RAD CAP SOLD
TOMEI OLD SCHOOL ECU SOLD
Photos of the steering wheels added:
350mm Deep dish suede steering wheels x2. Came with my HKB boss kit that I purchased.SORRY NO HORN BUTTONS can't find it. These steering wheels will bolt up to the same pattern as Nardi wheels. I bought a Nardi wheel to use with the boss kit so no use for these wheels. $5 each or free if you buy something else and pickup.
Found some more stuff to sell:
Cusco Rear upper camber arms to suit R32 GTR ONLY. Bought new in May this year, used for about 4 months. Great condition $250
Cusco Rear traction arms to suit most Skylines and Silvias. Bought new in May this year, used for about 4 months. Great condition $250
Edited by chris86
  • 1 month later...
  • 1 month later...
Update to what's still left for sale. Everything else is gone.
R32 RB26DETT GTR Fuel pump (worked fine swapped out for high flow pump) - FREE or goes in the bin
R32 RB26DETT GTR factory fuel injectors (replaced because leaking) - $80
Cusco rear upper camber arms to suit R32 GTR (almost like new) - $170
Cusco rear traction arms to suit most Nissans (almost like new) - $150
Endless MX72 rear brake pads for Silvias S13/S14/S15 (brand new) - $100
R32 RB26DETT GTR factory Radiator (wasn't leaking swap due to upgrade) - $20
S15 SR20DET factory Radiator (wasn't leaking swap due to upgrade) - $50
Nissan RB26DETT Oil filter (brand new) - $10 or FREE if you buy something else
R32 GTR RB26DETT factory turbochargers (worked fine swapped out for Garrett -7s) - $50 for the pair
R32 GTR welded up HICAS rear wheel steering rack (simpler way to delete HICAS) - FREE or goes in the bin
R32 GTR engine bay HICAS pump (no issues removed due to HICAS delete) - FREE or goes in the bin
S15 rear brake calipers (3 broken & 1 fine) - FREE or goes in the bin
Genuine Nardi Classic 360mm black leather steering wheel with genuine Nardi Horn button & HKB Boss kit to suit R32 GTR (like new) - $300
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
