So here's the deal guys.
I've got oil spraying out of my dipstick tube as well as pushing my dipstick out of the tube about 150mm each time.
so clearly im getting pressure in the crank case
but ive tried all i can think of now im out of options, so far ive:
-replaced the PCV valve with a new genuine unit from nissan.
-checked all breather hoses to make sure they weren't blocked.
-done a compression test to make sure i wasn't getting excessive blow by that was causing oil to spray out. (read 140psi across all cylinders)
now thats where ive hit a wall..... i cant think of anything else to check =\
any ideas?
appreciate any help...thanks.
https://www.sau.com.au/forums/topic/435182-oil-spraying-out-of-dipstick/
just went and checked the rubber is pretty hard around the seal but its still fitting pretty firm
surely though that shouldnt justify oil spraying out of the tube right??
well damn i hope thats not the case.......
im not getting any smoke blowing out the exhaust so thats not looking likely in my case but i might still look into that if i cant get it sorted otherwise
Doing a comp test is all good & well for an N/A application, BUT, what's to say your rings are not responding when boost pressure is applied? The only way to truly cancel out your rings would be to do a cylinder leak down test.
I build, run & tune LARGE turbocharged stationary engines. I've encountered this issue before. Customer complained about an oil leak. Discovered to my surprise when going from idle to load @ about +10''Hg (max is 30Hg/14.7psi)) crankcase pressure was going from -.5'' H2O to +25'' H2O & popping both dipsticks along with twin fountains of oil till the rings responded at about +15''Hg then everything would settle down. This particular engine had issues rejecting heat through its heat exchangers, its dump radiators were too small & subsequently had alot of high jacket water temp shutdowns.
Piston rings hate heating up & cooling down. if the temps are high enough, over time, they start to lose their tension & don't respond very well to pressure changes.
Pressurizing your crankcase to the point of popping the dipstick out can only come from one place. The only other thing I can suggest as 'for the time being' fix is to get a little bit of heat shrink (for wiring), place it over the rubber, heat it & refit your dipstick to stop it popping out. Then just hope you don't start blowing out other seals!
I was just going to suggest a leak down test. :yes:
140psi compression test result isn't brilliant, especially if that was after cranking for a while. Do you have a catch can fitted?
I got similar problem whereby if I park my car on a hill it burns oil out the tail pipe...
Valve stem seals?
some really good info there thanks man
probably an easy fix there with a bit of heat shrink, but im not looking for a cheap fix here id rather get it sorted properly
and like you said id likely start popping seals lol....read up on another forum some guy just clamped the tube with a pair of vice grips :mellow:
looks like i should defiantly go ahead with a leak down test then and see how shes looking
Valve stem seals?
nah mate no catch can....... would be curious to see if im getting anything blowing out through the breathers as well as the dipstick now that you mention it
defiantly worth doing then if you think it will help
being that the breathers run back to the intake though wouldn't that cause a vacuum in the lines from the pcv valve and through the breathers though??
hence its at negative pressure anyways?.... thats just a guess
haha well lets just say
I've got a heavier foot than brian o'connor.... pretty hard
Antz. U thinking a vented can?
yup..would have to be...you could just stick little filters a top your cam cover vents , but this will most likely spray oil everywhere...
anyway, to keep it simple.. if can is vented, block pcv...if can plumbed back to intake, retain pcv...
i could tell you not to drive it so hard but you would probably laugh at me :P
If u need bud I can make u a vented can. But me thinks ur problem will be increased buy the -5s u just bought. Enjoy.
haha i know right.... thats why im tying to nut this out before i chuck em on
shit timing how it kinda came up the day i paid for them :glare: ...... lol
you do some fabrication work do you?
i actually do think i "might" have a catch can off my old 33 in the garage somewhere
ill have to have a look ....but otherwise ill get back to you about that one :)
A catch can won't really help, you'll only be increasing the size of your crankcase a little. If a leakdown test fails to show where the problem is, then testing on a dyno to actually measure the crankcase pressure is what will be needed.
In my previous post I mentioned a water column measurement: +25" H2O. This is only about 1 PSI. It was an 18 litre 6 cylinder. It didn't take much pressure to lift the dipsticks. Just letting you know even a little pressure loss can do big things.
When you do a leakdown test, try to test in KPA not PSI.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
