Ok, punk-collective, you now have buttons on the mobile skins for dark or light.
Also links to full version, and the full versions have links to mobile. One big circle.
I fixed a javascript error also, not sure if it was the cause of the PM error, let me know if that still occurs.
C
Cheers dude :)
Oh dear - I don't know how I ended up in here.
And SAU has had a makeover > couldn't find how to leave "Feedback"
Can you change theme using the buttons at the bottom?
Wait wait...I retract my dude statement; dark theme button doing nothing on the iPhone :(
So, going FROM light TO dark? I tested a billion times (roughly) last night ... does the Full Version button do anything? (Theres a 'mobile version' link at the bottom of the full version when viewing on a mobile.)
Did nothing on my android phone either
Got the app and liking it so far :)
As above? From what theme to what theme?
dark theme at times doesn't display text properly, it's dark grey on black on some threads hence I never use it
Yeah, this is because people either paste coloured text, or colour it themselves in the wysiwyg and they don't consider how it would look on a dark background.
:verymad:
:verymad:
Does OMG days ring any bells? a few of their sites had the same issue dark background and dark text.. hahaha
A few of their sites had lots of things.... :whistling:
The full version button works fine, as does the theme changer when in full version mode...but the dark theme button in mobile view does not. It just reloads the forum index in light theme. This is on iPhone 5S with latest firmware.
I'm with Birds, dark theme button not doing anything when in mobile view. I'm on iPhone4
Of course you're with me; you never left!
It seems you can have only one Mobile skin. :(
The method I'm using works fine on desktop versions but doesn't change the mobile version AND changes your desktop to be the mobile version.
I've found another dark mobile skin on another site I'm going to grab and use, I'm hoping it is a decent midway between the dark and light skin haters.
Looks alright so far; will take some time to get used to. I like the extra GUI buttons and graphics. And it's at least friendly on the eyes in the dark. Visibility of "likes" is good.
Cheers!
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
