The FIA has contacted Formula 1 drivers to select the permanent race numbers they will carry from next year.
AUTOSPORT understands that the FIA has requested all drivers to nominate their preferred number, along with a second and third choice, to be lodged before Christmas.
This will allow the numbers, which will be carried by drivers for the rest of their grand prix careers and will range from 2-99 with number one reserved for the world champion, to be allocated at the start of next year
http://www.autosport.com/news/report.php/id/111841
In a widely-rumoured move, Adrian Sutil has been confirmed as one of Sauber's two drivers for 2014.
http://www.planetf1.com/driver/3213/9071681/Sutil-confirmed-at-Sauber
A McLaren MP4/4 used by Ayrton Senna during his victorious 1988 World Drivers’ Championship campaign will be on display at the Top Gear Australia Festival in March.
Sydney Motorsport Park’s Top Gear Festival will be highlighted by an appearance from Daniel Ricciardo in a Red Bull RB7, as well as the opening round of the Porsche GT3 Cup Challenge.
http://www.speedcafe.com/2013/12/13/senna-mclaren-set-top-gear-festival/
first, shitty turbo noise
second, ridiculous double points
third, individual numbers to sell more merch to idiots
fourth, penis noses... https://twitter.com/ScarbsF1/status/411505972478107648
fifth?!?! what horrible move can be schemed up next!!
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
