Much better!
But that reminds me I need to order a leave me alone I know what I'm doing t shirt before Melbourne.
They don't sound as terrible now that they're pushing a bit harder, still not F1 though
Just wait till the season starts. None of the drivers will use more than 70% throttle because they'll be too busy saving fuel.
I want to look forward to it, but I can't shake the feeling that Bernie has bent this formula over and is giving it the no-lube cavity search for cash. It's f**ked. Gimmick ideas like DRS to "make a better show" - gay. No refuelling on "safety" grounds yet the lack of fuel load as a strategy variable means everyone just tries to ration it. Tyres that deliberately go off and have a narrow operating window means everyone rations this too. Can't drive too hard - can't afford the fuel bill or to have the tyres go off.
JAS-25T you better upload that 2004 vid before I slit my wrists, this season is depressing and it hasn't even started yet :P
Just over 2 weeks until Melbourne...
Watching them cruise around slowly, conserving fuel, is going to be hard going.
Practice 1,2,3 at turn 1-2 will be the highlight IMO the rest is shaping up like a solar car challenge.
I cruise around slowly conserving fuel for work, and i gotta tell ya... it blows
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
