So who's tipping what for the Malaysian GP?
I'm quietly thinking Mercedes are going to have an engine failure of some sort, something about Hamiltons interviews since Melbourne make it seem like he/they are not entirely confident with the engine he will be using
If Rosberg's has the same potential issue then being the engine that has done more km, there might be a problem with his car
Or they might walk away with this one again, who knows.
Will get to see some real power comparisons with the long Sepang straights at least. See how the Ferrari stacks up to the Merc, I think the Renault is behind so we will get to see that for sure or not as well
Hoping Ferrari have made a step forward, hope Kimi has a better run
Rosberg's worked which is a good start and maybe an indication it will continue to work. They only get five (?) per year so you would hope one gp hasnt knackered it.
Predicitng Ricciardo will continue to dominate his fragile team mate.*
Hoping the Caterhams qualify nowhere near the Williams.
*May have gone somewhat early with the domination call.
My money is on a very strong weekend by Williams. They generally go alright around there and then fall off the face of the planet until the end of the year.
Will be very interesting to see the racing as there are plenty of overtaiking opportunities at Sepang
Well you can always hope. Problem with teams going better than they should is they almost invariably find some way of stuffing it up. eg Bottas in the wall or it rains and they have no wet weather pace or some other random reliability thing that screws a good weekend.
Wish I could pocket a dollar for every time multi 21 gets trotted out this weekend.
f**k. Like I said, NOONE in here is going to decide what the outcome is. Its pointless arguing like this.....
Just wait till the f**king appeal and then everyone will know
f**k. Like you said, NOONE in here is going to decide what the outcome is. Its pointless discussing it like this.....
Just wait till the f**king race and then everyone will know
:P
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
