UMERICA---FARK YEH!
Should be interesting. Building a team up from scratch...real question will be whose engine? Honda? Surly not Fezz. Have they ever supplied good customer engines?
It's rumoured to be Ferrari powered.
So whi is a gambling man. My money is on RBR winning...real test of the independence of the tribunal
..oh by win I mean found not to exceed the fuel flow limit...from there how the politics plays out will be interesting. Reading some various resports to the letter of the law RBR shoudl be ok...but the intent and spirit...and egg on FIAs face...umm...will be interesting
Stefano Domenicali has reportedly resigned as Ferrari team boss with an official announcement coming late Monday
He has been a spectacular influence over the last few years, imagine if his scowling face hadn't been there to urge them up to the level of also rans.
"We respectfully submit that the most effective way to ensure that Red Bull do not flount further instructions from the FIA is for this court to recognise the severity of their infringement and to impose a further sanction upon them which is to be suspended for the rest of the season, so that they are acutely aware."
Farking Mercdes. They got their QC straight out if their undergroung SS training school.
Come in RBR!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
