Unless you wrote the rules so the n/a engines were competitive against the turbos, no one would ever choose to run an atmo setup
The turbo engines were a joke when Renault started using them in their GP car in the late 70's, but as we all know, after a few years worth of development gave them the advantage, everyone tossed the n/a motors and got themselves some psi
Thats '95 isnt it? Epic on board. I remember watching that race ... Wish they had of shown all that on board back in the day. I used to love Alesi and Fezz back in the day.
Yep 95, I was 4 years old lol.
HAH gayyyyyyyyyyyy
he is like 19 and rich so lucky him to have what looks like a loving GF
He's 22 and "only" gets paid 400,000 per year...
But yes I think he and his mrs look very cute.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
