Interesting you say that. I am now reading on forums etc that Rosberg turned up his engine in Bahrain and in Spain Hamiltion turned it up to keep him behind. Everything I have read from Lower and Toto suggests that it was only Hamilton that played with engine spec against teams instructions. In Bahrain Rosberg was able to do so as it was his strategy to do it at that part of the race...so wasnt disobeying the pit wall in doing so. Seems Lewis saying Noco did the same thing in Bahrain is what people are remembering....and that is a statement out of context
Does anyone have a link that confirms Nico disobeyed the pit wall in Bahrain?
http://en.espnf1.com/f1/motorsport/story/160127.html
However, Wolff revealed that the tension dates back to the epic battle between the two in Bahrain where Rosberg was using engine modes that Hamilton was not and then Hamilton did the same when the pair were racing in Spain in two weeks ago. Wolff played down the significance of the two incidents, but said it had added to the tension in Monaco and would not be allowed in the future.
"In the last couple of races we had some little fouls left and right, and in the team we made sure this is not happening again," Wolff said. "The most obvious bit is you can play around with the engine modes, so this is not happening ever again.
Cheers, that suggests that Rosberg may have disobeyed the pit wall. Other quotes suggested that Rosberg was allowed to be in that engine mode and Hamo didnt understand why Rosberg was allowed to use a different setting...seemingly associated with Rosberg running the more conservative tune when on the harder tyre.
I recall thinking that was odd as if my memory serves me right comign down to the last laps in Bahrain Rosberg had used more fuel so didnt really support he had been in a more conservative engine setting mid race
yeah ive heard different things too, i think in the f1 telecast they talked about the engine mode being one that they are never to use.... but who knows....
in other news
http://en.espnf1.com/f1/motorsport/story/161097.html
'murica....
Yeah certainly sounded a little but suss. Every other time they'd choose to come out last so that they can shut the car down early if they aren't going to be beaten so as to save the tyres, etc.
It's going to be an interesting run into turn one. I think that if homo can get in front into turn one he will lead from start to finish. I don't think britney has the overall pace that homo does, he just managed to turn it on for 1 lap
yeah definately he was so close with a couple of mistakes, so yeah rosberg's gonna have to pull something out of his arse....
hamo has said going out last was prob not a good idea getting caught up in traffic....
maldanado reprimand for not putting his steering wheel on...
hopefully williams can have a good race!
Disappointing for Williams. I think Perez was at fault but Massa showed today that he is past his best and really should have got the job done as soon as he arrived on the bumper of Vettel. Cant help but wonder the 2012 Williams would have had if they kept Rubens and this year if they had someone like Romain
Funny to see Button in 4th...the guy is quick for one stint in 6
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
